E manage injector control... What size?
Old Mar 20, 2005 | 07:22 PM
SCvortech's Avatar
Default E manage injector control... What size?
Im looking into getting a Emanage for my SC S2000.. It says that it will control
%150 larger injectors.
Whats the factory cc injectors that come in our cars?
Whats the Largest injectors that it will control?
I have no other mods but the SC. Is it worth it to go BIG with the injectors so I dont have to replace them after some future mods?
Or should I go with 440cc till other mods are perfomered?
Black box that comes with the Vortech kit, Does that control injectors or just timing? Should I remove it and use the timing control wit the Emanage?
Thanks again for all your help!!
Old Mar 20, 2005 | 08:03 PM
Slows2k's Avatar
360cc is what most Stock injectors flow test at. The E-manage can control 550's, but for a stock boost Vortech, 440's will suffice. Just make sure you remove the FMU after adding the 440's.
The 00-03 Vortech kit comes with 2 boxes, 1 is a Map sensor clamp, which can be remove and the same function done by the e-manage. The other box is a timing controller. The Vortech controller has more accuracy and better functionality that the E-manage timing control.
The newer 04 kits come with an Aux injector, most likely a fuel and timing controller. They haven't been delivered yet, so Details on the 04 kits are fuzzy.
If you staying with stock boost, a E-manage is sufficient. If you are wanting to go for more power/boost etc, Get an AEM EMS, You won't be limited by a piggyback controller.
Old Mar 20, 2005 | 08:29 PM
SCvortech's Avatar
thanks SLOW
should i get some 550cc injectors or will tuning them down be too hard till i do some more mods
Old Mar 21, 2005 | 03:11 AM
fperra's Avatar
Stick wih the 440's. The 550's are known to cause driveability problems.
Old Mar 21, 2005 | 02:08 PM
SCvortech's Avatar
what Impedance are the injectors? Will 440cc for a RSX work in the S2000? Thanks
Old Mar 21, 2005 | 03:08 PM
Slows2k's Avatar
You'll use high impedence 440's, the same a RSX would use. On both cars you must change the plugs for the injectors, as no one offers drop in replacement high flow injectors.
Old Mar 21, 2005 | 04:54 PM
SCvortech's Avatar
thanks again for answering all my questions!!!!
Venomous S
Oct 23, 2005 10:50 AM
SCvortech
Mar 17, 2005 02:58 PM
honda9krpm
Jan 2, 2004 06:33 PM
S2K
Aug 20, 2003 08:19 PM
SC-SUZUKA
Jun 3, 2003 04:59 PM
