e-Manage Wiring Info
Old Aug 31, 2005 | 09:14 PM
folex187's Avatar
I wonder if Honda can order the plugs individually. The tough part would be finding the matching female connectors.
Does vtecfrog even offer a harness that includes space for all three plugs?
Old Aug 31, 2005 | 09:25 PM
Stratocaster's Avatar
Yes, the VAFC harness has the wires needed to connect all three e-manage harness. the e-manage wire is long enough to route under the drivers seat from the harness. So that is where I installed mine.
Old Aug 31, 2005 | 09:29 PM
folex187's Avatar
Yes, I know it connects the three emanage plugs but the ultimate uses a fourth so I was wondering if it connects all three oem plugs?
Old Sep 1, 2005 | 05:03 AM
Actually e-Manage uses two harness and e-Manage Ultimate uses three. The above diagrams are both for harness A. The ignition harness is B (comming soon to this thread)
Here is the e-Manage Ultimate connector info.
Old Sep 1, 2005 | 01:41 PM
Since the ignition is wired in firing order (as seen here)
It only makes sence that the Injectors are wired in the same order. (As seen here)
This make sence to me, as the injectors do fire in the same order. but how does e-mange adjust the injectors. It it takes the signal and just extends it to increase the duration, then it really would not matter.
Anyone have an opinion on this?
Old Sep 1, 2005 | 05:43 PM
folex187's Avatar
I can't wait to get wiring. Those diagrams are awesome. Stratocaster- would you like your tip money now or later
Old Sep 1, 2005 | 07:40 PM
AusS2000's Avatar
The injectors are interesting. Mine were wired 1-1, 2-2 etc and it ran fine although did have some low range stumbles. I wonder if the injectors should also be wired in firing order?
Does our ECU do sequential injection? If it does I expect it should be wired in firing order and this may explain my issues.
Old Sep 1, 2005 | 07:53 PM
Well I traced the OEM engine harness. The Injector number in the connector is the same as the cylnder number. I figured I would wire one up and test it. Like I said it makes sence that it would work that way too.
Thanks for the feed back.
Old Sep 2, 2005 | 07:29 AM
I wire my harness up last night and it idles great. I talked to a Tech friend, about this and he said that it would idle poorly, but run fine if they were wried wrong. So I think that might have been the issue. I am going to publish the updated Injector wiring.
Thanks again for your input on this subject.
s2konroids
Sep 21, 2010 04:29 PM
kaissi
Dec 4, 2009 02:48 PM
jareds2k
Mar 22, 2005 12:21 PM
jbotstein1
Nov 21, 2004 10:10 AM
