Educate me on Upgrading to the GTX3582R
I see that they are not sold with the housings, so would I just use my old one? Also being I have a divided T4 flange what what I need to do to make this work, or would it just be swapping of compressors?
Might make the jump for the summer
Originally Posted by red@9k,Jan 4 2011, 01:40 PM
If u ugrade, sell me the turbo. It's exactly what Im looking for.
Originally Posted by ScorpionT,Jan 4 2011, 02:21 PM
Yes, you can reuse your 35R turbine housing and swap in the CHRA and compressor cover. Simpe swap, as the compressor side is the only difference.
Originally Posted by JoeyBalls,Jan 4 2011, 05:42 PM
ok so I can do a clean swap and still use the divided housing? saweet. I wonder how much more power would I be able to make?
^ sound just like me
, yea I thought about that, I can't go much past 23psi with stock Fuel set up on pump/Meth. Seems like I would have to upgrade the fuel system and do the GTX upgrade at the same time, that would be nice
so..............how much for an upgraded fuel system anyway?
HMFIC I run 21lbs as a high
, yea I thought about that, I can't go much past 23psi with stock Fuel set up on pump/Meth. Seems like I would have to upgrade the fuel system and do the GTX upgrade at the same time, that would be niceso..............how much for an upgraded fuel system anyway?
Originally Posted by JoeyBalls,Jan 4 2011, 01:58 PM
Looks like I can use my current housing, would ya take my current turbo minus the housing?
