EFR 7064 Twin Scroll / IWG / Pfab Top Mount / V-Mount build
#32
Depends on what I end up doing. I've always made my own lines for nearly everything, however, I am tempted to make a hard line for the oil feed. If I do that, I will need to pick up some tools. I like the idea of being about to route a hard line where I want it and not have to keep a braided line from rubbing or be attached somewhere.
#33
#34
Nice build! I was hoping you'd create a thread. There aren't too many well thought out FI track builds. Is there a reason you opted to go with such a big turbo? That's a divided t4 turbine housing right..? What's your power goals?
yamahaSHO (01-09-2017)
#35
I didn't think this was really a big turbo at 56 lbs/min, but I think I can get it to spool within reasonable usage and hang on I top. Boost will likely settle around 10 PSI, likely in the 400ish whp range. It's also the smallest B2 frame they make and I don't any B1 frame will keep up with this motor on the exhaust side, on track. Yep, it's a divided T4 twin scroll and a paired manifold.
#36
#37
The 7163 would likely choke the exhaust at high RPM, especially at constant high RPM. Robert Thorne and I spent some time working out a good turbo for the application, so I'm pretty confident in it, especially since I'm not trying to make a typical Subaru curve. I intentionally went for a larger A/R and twin scroll for helping it stay efficient for a large portion of the powerband... which isn't going to be very high.
For street duty, I probably would have gone with the 7163.
#38
I'm not familiar w/ BW turbos.. Is a B1 frame on the hot side a t3 flange, and the B2 is a t4 flange..?
#39
The idea of the large hot side is to let it breath, while pairing the cylinders properly for a twin scroll to help with the spool.
The B1 vs B2 is in reference to their frame/cartridge, with the B1 being smaller.
This isn't my picture, but it's a exact comparison between my 7064 (B2) vs my 6758 (B1).
#40
