Emanage Help
Old Sep 26, 2008 | 08:27 AM
Sub2K's Avatar
Default Emanage Help
hey so i just purchased a emanage Ultimate with PnP harness and i got it all hooked up with my wideband which the sensor is toast because the guy who welded my bung used it as a holder for the new bung as he welded!!!!
anyways i removed the esm and hooked it all up and set the boost cut off which i have been reading ?? is supposed to lock the map like the Comptech ESM at 2.93v well now when i give it any gas over 30% it bogs hard like it just wants to stop!!!
i just want it to do what the esm was doing till i get the time to get it tuned or get my wideband sensor replaced.
aaaah please help
Old Sep 26, 2008 | 09:23 AM
revhi's Avatar
Is it bogging at any rpm and did it throw a cel? Try map clamp voltage to 2.89
Old Sep 26, 2008 | 09:36 AM
Sub2K's Avatar
pretty much and rpm i floor it in but it gets worse above 3k. i have tried 2.85 2.9 but ill give that 2.89 a shot if it doesnt work what do you think about leaving the esm in with the emanage
Old Sep 26, 2008 | 06:07 PM
revhi's Avatar
If 2.85 didnt work, 2.89 is not either. Check all your connection, make sure all wires are soldered. Unplug emanage and see if it reacts the same, do not boost though when unplugged. You can still drive normal.
Old Sep 26, 2008 | 07:01 PM
Kirpich's Avatar
What's your wideband saying?
GreeceS13
Αγοραπωλησίες
Jun 19, 2013 01:22 AM
Sub2K
Sep 26, 2008 07:57 AM
kylemonster85
Sep 17, 2008 11:27 AM
kylemonster85
Aug 30, 2007 11:00 AM
batikan
Apr 18, 2006 04:09 PM
