EMERGENCY! Please HELP! ***UPDATE!***
OMG, F***!!!!!
Where the hell do I go about getting one of these fittings??!!
I snapped it off trying to tighten the connections to put oil back in my car with my new Comptech S/C....
Any ideas??
What is the part?
It the blue piece that replaces the oil drain bolt....
Please help me??
-Matt
*** Check below for update***
Any ideas??
What is the part?
Please help me??
-Matt
I bought a replacement for that part from comptech for $20. The only reason I did it was because I noticed a little wear on the threads around the 4th oil change. I figure I won't need to replace it for another year, but figured I should have one around "just in case".
Originally Posted by duff0000,Jun 5 2006, 11:24 AM
im about to do my first oil change with the comptech on, any advice on how hard, or soft lol this should be tightened?
BTW, the 14mm to -8 is NOT A STANDARD SIZE! Comptech had these made for our kit! Be aware a this part is nowhere to be found in the Aeroquip catalog...
**** Update ****
Well, I put together a list of all the speed shops in town last night, and started calling them at 8AM... At around 10, Titan Motorsports picked up and said to try Hydraulic Equipment (business in Orlando)...
So I called them... They had a 14mm to -6 AN connector (I needed an -8...
), but he thought we could figure something out... I sped over there... (Not really, I was in my Mom's caravan, LOL)...What I ended up getting was a 14mm (1.5 pitch, same as the drainbolt) to -6 AN connector... They didn't have a -6 to -8 adapter, but they DID have a -6 to -8 90degree adapter... So I bought that...
Fearing that the oil return line which has a 90 degree connector on it already, would have a compatibility problem with my new 90 degree adapter-- I also bought a Straight -8 AN hose end... I didn't end up needing it, but I thought better safe than sorry...
I got home, it took 10 minutes to get it all together! DONE!
I did have to finagle the return line a little to get it to line up, but it worked!
I think I may just leave it like this, but Comptech will send me a new -8 to 14mm connector for $20 + shipping...
