Emissions? with EMS and turbo
Originally Posted by Spec_Ops2087,Mar 29 2007, 10:22 PM
For only 9psi (thats more like 375hp
) emanage is more then enough. EMS is def not needed for such a low boost level (its overkill).
Check to be sure, but I'm 99% sure the emanage works on the 06 cars.
) emanage is more then enough. EMS is def not needed for such a low boost level (its overkill).Check to be sure, but I'm 99% sure the emanage works on the 06 cars.
can anybody confirm this?
Originally Posted by Spec_Ops2087,Mar 29 2007, 06:36 PM
The aem ems disables the OBDII port so no, you will fail emissions.
Originally Posted by Spoolin,Mar 30 2007, 04:27 PM
Not all emissions checking places check and plug into you OBDII port. Here in IN when they had emissions, they did not plug into the port at all or get in your car. They only put a reader in the tail pipe and had you drive through gears on the dyno.
Originally Posted by Spec_Ops2087,Mar 29 2007, 08:56 PM
That is incorrect. Check the main page http://www.hondata.com/
With the K-pro, or a piggyback, you should be able to pass emissions. This is if they do a quick check(only plug in the OBD 2 port, no visual or exhaust sniff). As long as this passes, you should be good to go.
I think you can also run the HKS f-con pro. There was talk that it kept the OBD 2 port functioning, but don't quote me on that.
Chris
Chris
I was saying pre06 ecus are not programable, I wasn't talking about emissions. [/QUOTE]
I'm just confused
I thought he had a 2001... lolAnyway, carry on
Chris
Originally Posted by cpoz,Mar 30 2007, 11:00 PM
I think you misunderstood what I was talking about.
Chris [/QUOTE]
Bulldog has an 06 (who I was talking to in one of my posts)
The op has an 01 (he just asked if the ecus were programable like the 06's, which I responded no)
Maybe that clears it up
yea i had ems on the car when i had the CTSC setup.
only 1 o2 sensor was used though so i couldnt pass emissions.
since then i parted out my whole car... now i wanna keep it and build it this time and go turbo. just exploring the different tuning options. If i have to ill get the motor built... then get it echecked then put the turbo on. That was ill have at least 2 years b4 i have to get it checked again,
Originally Posted by Nick32,Apr 2 2007, 09:15 PM
will hondata be capable of 500+ hp or will full aem ems be needed?
