EMS Misfire FIXED
Old Oct 10, 2007 | 07:39 AM
chairmnofthboard's Avatar
I'm using BKR7E spark plugs.Come to think of it, it started doing the missfire when I installed the Blower as well as the plugs.
Is it safe to run the Stock S2000 plugs with a supercharger?
Old Oct 10, 2007 | 09:28 AM
Soul Coughing's Avatar
also check your compression and a leak down test... just to be sure
Old Oct 10, 2007 | 09:31 AM
Sideways's Avatar
Yes, just don't go crazy since they are warmer.
Old Oct 10, 2007 | 12:31 PM
I was thinking that, but it only does it with the EMS not the stock ECU. I'll do one anyways.
Old Oct 10, 2007 | 12:32 PM
well I replaced the 7's with a new set of 7's. Still did it. now I'm going to replace the 7's with the Stock plugs
Old Oct 10, 2007 | 12:33 PM
Define going crazy??? lol
Old Oct 10, 2007 | 08:21 PM
Problem isolated. Cyl #1 not firing. Will start to fire at hwy speeds.
Replaced, plugs, coil packs, and injectors.
cyl NOT FIRING with ems, will fire and run right with factory ECU. I guess it's back to Dyno to see why it's not firing.
Old Oct 10, 2007 | 09:09 PM
S2oooNvegas's Avatar
EMS is bad, this happens all the time. replace it
Almost Engine Management
Old Oct 23, 2007 | 06:57 PM
Turns out it was bad software in the EMS itself. Garvin at AEM took care of it with out any delays.
thanks Garvin!
Old Oct 23, 2007 | 11:20 PM
QuagmireS2k's Avatar
thanks Garvin!
Well thats good. I knew when i heard the problem it was not right. when you get your car fixed i get the first ride in it.
