Engine builders chime in
Old Jun 5, 2012 | 03:47 PM
cuci591's Avatar
Default Engine builders chime in
Hello all, I am in the process of building my ap1 block. I am not new to rebuilding engines but I am new to the s2000 and just wanted to know if they have the same similarities as the b series engine. On the b series engine they use color codes on the bearings and I wanted to know if this was the same for the f20 motor. If anyone has any tips that made the process easier please chime in as I dont want to make the same mistakes Im sure some of you have made. Thanks in advance.
Old Jun 5, 2012 | 03:55 PM
08s2000CRbackinblack's Avatar
i believe they do. not sure on how accurate this is>>>>>
Part no. Description Required Quantity
13211-PCX-003 BEARING A, CONNECTING ROD (BLUE) (DAIDO) 8
13212-PCX-003 BEARING B, CONNECTING ROD (BLACK) (DAIDO) 8
13213-PCX-013 BEARING C, CONNECTING ROD (BROWN) (DAIDO) 8
13214-PCX-003 BEARING D, CONNECTING ROD (GREEN) (DAIDO) 8
13214-PCX-013 BEARING D, CONNECTING ROD (GREEN) (DAIDO) 8
13215-PCX-013 BEARING E, CONNECTING ROD (YELLOW) (DAIDO) 8
13216-PCX-013 BEARING F, CONNECTING ROD (PINK) (DAIDO) 8
13217-PCX-003 BEARING G, CONNECTING ROD (RED) (DAIDO) 8
13321-PCX-003 BEARING A, MAIN (BLUE) (DAIDO) 10
13322-PCX-013 BEARING B, MAIN (BLACK) (DAIDO) 10
13323-PCX-003 BEARING C, MAIN (BROWN) (DAIDO) 10
13323-PCX-013 BEARING C, MAIN (BROWN) (DAIDO) 10
13324-PCX-003 BEARING D, MAIN (GREEN) (DAIDO) 10
13324-PCX-013 BEARING D, MAIN (GREEN) (DAIDO) 10
13325-PCX-013 BEARING E, MAIN (YELLOW) (DAIDO) 10
13326-PCX-013 BEARING F, MAIN (PINK) (DAIDO) 10
Old Jun 5, 2012 | 03:59 PM
H4RD ON's Avatar
Why not use some ACL's?
Old Jun 5, 2012 | 04:01 PM
H4RD ON's Avatar
I've always used ACL race bearings. H, HX, and H .025 ....mix and match to get the exact clearances you need.
Old Jun 5, 2012 | 04:05 PM
cuci591's Avatar
Ive thought about going that route but I have always had beeter luck using oem bearings.
Old Jun 5, 2012 | 05:40 PM
teamvalorracing's Avatar
Plasti gauge my son. It will tell you the tolerance you need. Then compare that with the stamps on the motor as those letters correspond with specs as well.
Old Jun 5, 2012 | 06:35 PM
H4RD ON's Avatar
people still use plastigauge?
Old Jun 5, 2012 | 10:11 PM
redboost10's Avatar
How can you not use plastigauge?
Old Jun 5, 2012 | 10:27 PM
CD7SirAccord's Avatar
Dial bore gauge
But they're pretty expensive, that's why most people don't have them.
Old Jun 6, 2012 | 03:50 AM
vduber's Avatar
Plasti gauge ftw
