ENGINE LOAD
Old Sep 24, 2013 | 11:54 AM
s2000gt35's Avatar
Default ENGINE LOAD
hi guys
Just want to know what is you engine load on your aem ems at idle when car running. My car has built block and fullblown stage2 kit with precision 6766 turbo. im just curious if mine is normal beacause im at -0.6 psi. i think normally is around -8 or -9 psi. what can affect this.
Old Sep 24, 2013 | 02:06 PM
sohc_mshue's Avatar
sounds like you have a vac leak around the map sensor or you're cal is off.
Old Sep 24, 2013 | 02:39 PM
s2000gt35's Avatar
no vacuum leak the engine run really fine at steady 1100 rpm but really rich about 10.5 maybe its my calibration because i put the stock s2000 map and adjust my wizard and setup my throttle range. i just want to fix it to go on the dyno for tune but i dont want to drive at 10.5 air fuel. do you think if my boost solenoid is not wiring can make a vac leak. the vacuum line is connected but not the power and in the ems.
Old Sep 24, 2013 | 02:49 PM
sohc_mshue's Avatar
check the o-ring on the sensor
Old Sep 24, 2013 | 03:31 PM
yamahaSHO's Avatar
Do a proper boost leak test and find your leaks.
Old Sep 24, 2013 | 05:06 PM
herecomesboost's Avatar
Could you post your calibration?
Old Sep 24, 2013 | 09:36 PM
s2knoob89's Avatar
Vac leak or calibration
Old Sep 25, 2013 | 05:56 PM
s2000gt35's Avatar
ok i think i have found my trouble i have not change the option on the map sensor option according to this. now im try to change this value but im not able to put the .08 and the 4.88. im just able to put 0 and 5 and 4 for the scalar. Any person have idea to put the right value.
omni power 4 bar calibration
min voltage .08
max voltage 4.88
scalar 3.8
load offset 15.0
filter 10
frequency 0
Old Sep 25, 2013 | 08:52 PM
hybrdthry911's Avatar
You should be able to put any value you want in there, make sure to press enter.
I hope the car hasn't been tuned yet?
Old Sep 26, 2013 | 09:32 AM
s2000gt35's Avatar
NO its not tuned at all but when i put .08 and press enter the aem program put 1 and the 4.88 aem put 5
