Engine removal questions
Old Apr 1, 2012 | 04:31 AM
vduber's Avatar
Default Engine removal questions
Almost there I got started late yesterday so she's not out yet. Question did you guys unhook the wiring harness from the ecu and feed it through? I'm removing the motor/trans through the top as a whole(I know Im gunna scratch shit no worries) I Dont need to loosen the starter since I'm taking them out as a whole correct? Btw 6mm driveshaft bolts suck
Chris
Old Apr 1, 2012 | 05:25 AM
teamvalorracing's Avatar
Yes, i pull the harness from the ecu and leave the engine side intact. Its easier that way. The only time i pulled the engine and trans as a whole though the top is after making a removable crossbeam. The car will have to be skyhigh and the engine/trans damn near vertical to come out that way. Let us know how it goes bro.
Old Apr 1, 2012 | 05:43 AM
vduber's Avatar
Yea I know that's why I'm using a forklift as a crane and getting the car pretty damn high of the ground. Thanks
Old Apr 1, 2012 | 12:23 PM
Corey Maurer's Avatar
why not just go out the bottom? drop the subframe and upper control arms.. simple
Old Apr 1, 2012 | 02:44 PM
Irishflame27's Avatar
Go out the bottom, drop the subframe and its a breeze, I just unbolt the lower ball joint....
Old Apr 1, 2012 | 03:19 PM
ghettocrxsi's Avatar
Go from the bottom, less chance of breaking sensors if you have the stock cross member in place.
Old Apr 1, 2012 | 04:44 PM
gsx2004's Avatar
^+1
Old Apr 2, 2012 | 03:07 AM
vduber's Avatar
Well boys and girls after a long ass day and night she's out. Half way through the day I went against my original thought (better judgement) and just separated trans in the car and dropped that and then yanked the motor out. Didn't drop the subframe cause I have to tow the car to a different location today so I felt it to be. A pita to drop the subframe only to separate it on the ground and then rebolt it. Deffinately happy I changed my mind cause stuff would deffinately got f***** up regardless that I was using a forklift. I'll try to get up some pics my buddy took later. Working on 1.5hrs of sleep so I'm completely dead at work but it will all be worth it hopefully
-chris
Xherrox
Nov 15, 2008 10:58 PM
crank
Sep 11, 2008 03:48 PM
ack5252
Mar 23, 2008 02:01 PM
Bigeggroll
Oct 20, 2007 04:51 PM
