EPS box relocation...
Old Aug 30, 2008 | 08:15 AM
AndyFloyd's Avatar
Default EPS box relocation...
Alright, so Im starting to wrap all of the stuff with heat-tape on the turbo side of the engine. I was just gonna rotate the fusebox 90* so that it sits along the firewall. I moved the metal EPS box ( what I believe it to be called ) to where the battery used to sit. I used one existing hole and then drilled a 2nd for it. I just want to make sure its ok to mount the EPS box flat instead of along the fender where it was to begin with. I am going to be heat wrapping everything on this side of the engine, and am also using a turbine heat wrap kit so the temps should be in check for the most part. I just want to her from people what they did, and what kind of bracket they made to have the fusebox sit along the fender. Thanks guys, you all have been a huge help.
umair
Nov 5, 2015 05:01 PM
Dck
Jul 7, 2015 03:26 AM
tx2K
Jan 3, 2013 01:01 PM
Suzuka_Joe
Jun 22, 2011 03:23 PM
mys2k3
Mar 3, 2010 02:10 PM
