Exhaust cut out valve, too loud or modify
Old Jun 17, 2013 | 01:32 PM
s2konroids's Avatar
Default Exhaust cut out valve, too loud or modify
Hi guys,
I'll be going with an inline pro stage 2 street kit borg warner S363 and will install an exhaust cut off valve.
Will it be insanely loud? - if so can you modify the pipe or add a small muffler to make a little quieter?
I hear it helps performance and the turbo spool up time, I'll running the stock exhaust (which has UK exhaust mod) and get the valve to open at around 6psi.
Thanks
Old Jun 17, 2013 | 02:00 PM
soulicious's Avatar
I had a SP cutout installed for my S/C kit, but took it off since it was way too loud. I imagine that it won't be as loud with turbo. I suggest hearing how loud it is with one of your locals before forking out the cash or buying mine for cheap
Old Jun 17, 2013 | 02:03 PM
baZurk's Avatar
I will be running one for my setup. I have an HKS dual which has the same size piping as stock. The exhaust cut out will help a lot with spool, power, and I also believe heat. The stock size piping is very restrictive. If you are looking for anything around 400whp or above, I would consider it. It will not be loud unless you give it the beans.
Old Jun 17, 2013 | 09:02 PM
benes2k's Avatar
yes a cut out is louder than your average exhaust. especially at WOT.
Old Jun 20, 2013 | 08:56 AM
Trackforged's Avatar
Former Sponsor
So your telling me you don't want it to be too loud, so your going to install a cutout??
Evan
Old Jun 20, 2013 | 01:16 PM
s2konroids's Avatar
Evan
Read the post again.
Sophotrope
Nov 5, 2015 12:29 PM
rikhemi
Oct 9, 2010 01:11 PM
