Exhaust valves and guides recommendations
Old Dec 14, 2010 | 04:03 PM
Pawan's Avatar
Thumbs down Exhaust valves and guides recommendations
Long story short. I money shifted I have to replace exhaust valves and guides. Should I stick with OEM or go after market (e.g. SuperTech)?
SuperTech exhaust valves and bronze guides are less expensive than OEM. Is anyone using them?
Thank you in advance
Old Dec 14, 2010 | 05:29 PM
siadam's Avatar
Info on your setup and future plans would be nice before we make a suggestion.
Old Dec 14, 2010 | 06:32 PM
Pawan's Avatar
I'm currently running 10 psi on GT35R. I will be installing 2mm head gasket and will turn up the boost to around 15 psi.
Old Dec 14, 2010 | 07:36 PM
D1sclaimer's Avatar
Did your machinist tell you that your valve guide clearance is not in spec or do you just want to replace them?
Old Dec 15, 2010 | 10:38 AM
m R g S r's Avatar
don't swap HG's, well swap out to a new OEM gasket but don't swap to a 2mm HG.
might as well get inconel exhaust valves to stand up to the heat of launch control, and some stiffer springs/retainers while youre in there.
Old Dec 15, 2010 | 12:35 PM
InductionPerformance's Avatar
I fully agree with this post
Old Dec 15, 2010 | 02:11 PM
dsddcd's Avatar
[QUOTE=Pawan,Dec 14 2010, 08:03 PM] Long story short. I money shifted
Old Dec 15, 2010 | 06:21 PM
Now that I think of it. I can. Also pick-up some locks/keepers from whatever company you decide to go with.
Old Dec 16, 2010 | 05:59 AM
siadam's Avatar
I've been told my 2 different people, that you should use the same locks/keepers as retainers you are using. They aren't a "matched set", but the retainers are angle cut for specific retainers.
Old Dec 16, 2010 | 03:57 PM
Exactly. But. If I buy Ferrea retainers I tend to stick to Ferrea for everything else.
