Extended lug nuts for diff conversion studs?
Old Apr 8, 2007 | 01:29 PM
Venomous S's Avatar
Default Extended lug nuts for diff conversion studs?
For those of you with rear end conversions with the extended studs.
where can I purchase extended lug nuts for the stock 02 Honda Rims
M12 X 1.5 Honda rims have the ball/radius type of seat. All I seem to find on the net is extended nuts for the conical type seat for aftermarket rims.
Again, this topic is in FI as I am most likely to get answers here from hi powered turbo fellows that have done the diff conversion.
Old Apr 9, 2007 | 03:09 AM
Venomous S's Avatar
information bump
Old Apr 9, 2007 | 05:24 PM
m R g S r's Avatar
post on honda-tech
Old Apr 9, 2007 | 09:17 PM
cpoz's Avatar
Have you tried Summit Racing or Jegs?
I will add if you can't sort it out, have you thought about taking the stock nuts and just cutting the tops off??
I have diff. wheels, and rays extended studs, so I really can't answer your question...
Chris
Old Apr 9, 2007 | 10:00 PM
Asura's Avatar
ARP sells them buddy
Old Apr 10, 2007 | 03:08 AM
Venomous S's Avatar
Chris
Tried Summit, no luck so I figured not to even try Jegs
And yeah I did think about cutting the tops off as last option.
And Asura thanks, didn't even think about ARP. I know they do sell studs, but lug nuts
Old Apr 10, 2007 | 04:42 AM
PRS2K's Avatar
Inlinepro should be able to get you a set. I received studs in the kit.
Old Apr 10, 2007 | 04:55 AM
hboy7777's Avatar
lug nuts off of a 94ish accord with aluminum wheels, they are open end due to the center caps
Old Apr 10, 2007 | 07:02 AM
pwrofdrm's Avatar
^ That's a good idea.
Topline makes aftermarket ball-seat lug nuts. I can check for you later when I get to work if you'd like.
Old Apr 10, 2007 | 10:52 AM
Venomous S's Avatar
thanks but if you have the website I could check too
I'm actually looking for extended lugs though.
Accord lugs are probably short right?
