Fans not working
Old Sep 3, 2010 | 06:29 PM
jb34304's Avatar
Default Fans not working
I went to go tune my car today. It ran fine on the highway, then started running like crap when I got into town. I pulled into a parking lot checked the temps and It was 215-220 and shut the car off. I tried checking the fuse and the relay. The fuse looked okay, and the relay just clicks when I force the fans on. Any ideas?
Old Sep 3, 2010 | 06:37 PM
RedLineS2k10's Avatar
like click click click..?? try turning ur AC on to start the fan...
Old Sep 3, 2010 | 08:55 PM
jb34304's Avatar
Yea tried that. It clicks about three times a second. I tried forcing the fans to come on through the AEM. Under outputs/ configure outputs/ select output "LS6". Set the switch to activate when coolant reaches 100 degrees Fahrenheit. All it does is click until I disable that... I took the relay from the horn and used it for the fan relay, and used the fuse from the convertible top and placed it in the radiator fan slot. As I knew that fuse was working already. Still just got the clicking noise. Oh and the fan just turns really slow.
Old Sep 3, 2010 | 09:03 PM
Not an electronic expert, i sometimes hear a clicking sound, but its the relay clicking before the fans turn on.......I didnt know u could control the fans like that through the AEM, mine are hooked up to a relay and a switch...........
I would do a voltage check to the fan connections, my guess is, your not getting enough juice..
Old Sep 4, 2010 | 10:01 AM
jb34304's Avatar
I only forced them on to diagnose the problem. Any other ideas?
Old Sep 4, 2010 | 01:48 PM
voltage check, see if its getting the right amount of current?
Old Sep 4, 2010 | 03:01 PM
passmans2kny's Avatar
I had this problem, I got new relays and it's working now
Old Sep 4, 2010 | 03:46 PM
Here you go............
Old Sep 4, 2010 | 05:46 PM
jb34304's Avatar
I have that service manual. What page is that on?
Old Sep 4, 2010 | 05:57 PM
jb34304's Avatar
I will stop by the local auto parts store Monday if they are open and swap out the old relays. And if that doesn't work I will run the motor test. Thanks again for the pointers.
