FBM Stage 2 Turbo Kit 853hp!
Well.. its finally done! We switched our setup from the s372 with our custom manifold to our off the shelf Stage 2 Twin Scroll kit . We are getting ignition breakup at 32psi so I had to call it quits for the day. I think we can get pretty close to 900hp once we figure the ignition problems out. This was done on E70, which I feel is at its limit. The power curve is pretty rough due to the ignition breakup. The car still needs a little more tuning. I'm going to gap the plugs down some more and see if it clears up, but we'll will be releasing an upgraded ignition system very soon. This dyno run was revved to 9k. We plan on revving it further and hopefully see some 150+mph traps
Here's the setup
Motor
F20c ERL Sleeved block
FBM Spec Arias Pistons
Brian Crower Rods
FBM L19 head studs
Stock Intake manifold
FBM 74mm throttle body
Ferrea Valve springs and retainers
Ferrea Comp plus Valves
Turbo
FBM Stage 2 turbo kit w/6765 Twin scroll
Twin Tial MVR Gates
Tial 50mm BOV
FBM custom 1000hp intercooler
FBM custom exhaust
Fuel System / EMS
Haltech PS2000
Racepak IQ3
FBM Dual Pumps
FBM Fuel pressure regulators
FBM Dual Fuel rails
FBM 340lph pumps
ID 1000s for primaries
ID 2000s for secondaries
Drivetrain
FBM v160/v161 transmission conversion kit
FBM 5.9 Ford 8.8 Conversion kit with 3.73 final/eaton posi diff
Clutchmasters twin disc
Misc
FBM Radiator
FBM Radiator Hoses
Update, Misfire problem solved
Here's the setup
Motor
Brian Crower Rods
FBM L19 head studs
Turbo
Twin Tial MVR Gates
Tial 50mm BOV
FBM custom exhaust
Fuel System / EMS
Haltech PS2000
Racepak IQ3
FBM Dual Pumps
FBM Dual Fuel rails
FBM 340lph pumps
Drivetrain
Misc
FBM Radiator
FBM Radiator Hoses
Thanks bud, We'll be testing a few different turbos. I'll let you know how it goes.
Thanks
Hopefully we can see what it does soon.
Thanks
