feels like the s is slower
Old Sep 21, 2008 | 02:16 PM
sbrodacz's Avatar
Banned
Default feels like the s is slower
The s feels slower. Have I gotten used to the 11psi's? Is it time for more boost?
Old Sep 21, 2008 | 02:26 PM
Enthralled's Avatar
hum....whats the temps where you are? heat bog maybe? btw what WHP are you at currently with the Emanage Ultimate?
Old Sep 21, 2008 | 03:23 PM
Revenge's Avatar
3mm and up the boost!
Old Sep 21, 2008 | 04:03 PM
sbrodacz's Avatar
Banned
I don't have an aftermarket temp gauge but the standard one hasn't moved. I have the 3mm hg but I didn't have the pressure sensor so I was only able to tune to 11psi's. With the 3mm hg and 11psi I'm pushing 309 to the wheels. Its getting retuned on thursday.
Old Sep 21, 2008 | 04:10 PM
Revenge's Avatar
Cool
Then if you turn it up to 18psi you should be close to 400hp, that will be a 1 fast S.
Old Sep 21, 2008 | 04:11 PM
03silver2000's Avatar
what pressure sensor is needed?
rob!'s Avatar
buy a 3bar map sensor before you tune and retune for 475-500whp. its very normal to get used to the power of a car. id retune for more power. you are wasting a great setup on such low HP. youre car is capeable of 500 to the wheels safely!
Old Sep 21, 2008 | 05:28 PM
sbrodacz's Avatar
Banned
I'm not sure what pressure sensor it is.... Not very technical. I will be tuning a lot higher now with the pressure sensor. I also got bigger injectors. My 550's were at 80%.
What is a 3bar map sensor? I wonder if that is what I needed?
Old Sep 21, 2008 | 05:30 PM
rob!'s Avatar
yeah, the stock map sensor which is on the throttle body wont allow you to run more then the boost level you are at. You need a new map sensor that can read a higher amount of boost. You can get a few different ones but its probably easiest to just get the GM 3bar Map since its cheap and simple and allows you to run around 30psi.
Old Sep 21, 2008 | 06:15 PM
sbrodacz's Avatar
Banned
I've already got the greddy one for the emanage that will be installed this thursday for the retune
