Ferrera Beehive springs vs OEM
Yes you can, really though you should retainers made for the springs they designed em for. Otherwise they shift around a little and cause premature wear.
Honestly there's nothing wrong with titanium retainers, they wear a slightly faster but so what, it's a predictable service limit that you can plan for and it's a very easy part to change. Cheap and easy! If you get dual valve springs absolutely go with titanium retainers!
^ Why are you pushing steel retainers though?
If any engine needs titanium it's the F20/22c. The rpm is sky high, certainly titanium provides a safer limit before floating a valve, why give up that safety net for slightly more wear?
bc they dont wear out like titanium ones.. no you cant go as high a RPM as titanium but BUT dont have to worrie about them cracking
You don't have to worry about the titanium ones cracking either. You just have to replace them periodically because titanium is softer than steel that's all. It's not like it's a huge job or anything. It's pretty easy to do. I'd understand if you had to tear the whole motor down or something. IDK. I guess I just like the safety margin they provide.
My head is good to 10,000rpm on my F22c but I'll redline it at 9000 with a limiter but generally shift at 8500, the extra 500rpm will be used if I have to have it to avoid shifting gears in the middle of a corner or something but I'll avoid it as much as possible. The last 1000rpm past that will be for safety margin only. Chances are I could survive a misshift (mechanical over-rev) where others couldn't. Could happen...
