Hey guys I am going to be installing my AEM UEGO today and I have a few questions
1. Does anyone have a write up of their install of picture of where they ran the wires?
2. Is the wideband sensor going to be replacing one of the regular sensors or will it be a 3rd?
3. If I am using a greddy Emanage Ultimate will I be using the white or blue wires?
4. Does the Emanage Ultimate have a 0-5v input?
Thanks in advance guys!
not I
It will be a third sensor since you are using it with the ULT
the blue wire - its the 0-5V output
yes, but you will need to buy the "AFR option port cable" from greddy which is ~18$.
Mine was in the nose of the OEM CAT also (running TP now). Wires were run over the top of the tranny and up the driverside. You do need the A/F Harness Connector to connect the wideband 0-5 signal to the ULT front panel Opt/In 1 port.
