Finishing install ?s
For the time being can i leave the air pump functional like stock but instead of it getting filtered air from the intake pipe, just put a small k and n filter on it?
Where can i buy the greddy oil relocation sandwich plate oring?
What's wrong with the hks carbon?
Thanks guys almost done
Originally Posted by DBXFX,Sep 2 2010, 01:31 AM
1. I'm going to tap the girdle, 1/2" npt i believe. I have a 10-an oil drain end. Will this work OK? is brass ok to go with or should i pay more for aluminum.
-brass http://www.atpturbo.com/mm5/merchant.mvc?S...&Category_Code=
-alum. http://www.summitracing.com/parts/SUM-240118B/?rtype=10
2. As of right now, my tial 38mm wastegate dumptube is just a ~2" turndown, i plan to have it remade, but due to time constaints, i may have to tune it with the short one on. does the dumptube length effect the tune at all?
3. Do I leave that econdary air pump solenoid (i believe thats what its called) installed, the one that you have to mess with when installing an aftermarket intake.. connects to the throttle body area.
4. Is the FPR the best place to tap off for vacuum? I'll be running a vaccum block 1/4" npt inlet, 6 x 1/8" npt outlets.
5.Are name brand vband flanges and clamps any different than atpturbo's in terms of quality?
6. Where can i buy the greddy oil relocation sandwich plate oring?
7. Any pics of the hsk 75mm carbon ti? Does the 5" tip look rediculous?
