Fiveomotorsport's 1000cc injectors...
Old Jun 22, 2011 | 12:53 PM
Wydget's Avatar
Default Fiveomotorsport's 1000cc injectors...
Here is the description on their website. I'm looking for a set of 1000cc's and came across these. Any opinions???
a set of 4 (four) custom milled, high performance, high impedance, flow-matched fuel injectors custom fitted for S2000 or equivalent 2.0 4 cylinder engine -
Flow rated at 1000cc/min at 3 BAR
Each set is sold with a complete flow-data chart indicating individual dymanic and static flow rates at 3, 3.5, and 4 BAR at 25%, 50% and 100% for each injector, along with dead time (latency) at 14 volts.
You also receive with your injector set - a set of 4 (four) U.S. CAR to Keihin electrical connector adapters. (See photos).
This is a modified fuel injector set - We custom mill brand new German fuel injector cores in large-quantity batches to achieve the highest quality product.
This fuel injector is part of Fiveomotorsport's new "ASPHALT II" series of newest generation, flow matched superstreet and racing fuel injectors.
The injectors incorporate a single-hole modified disc fuel delivery nozzle with a wide cone spray/fog for excellent fuel atomization.
Use for naturally aspirated and forced-air/exhaust 2.0L 4 cylinder engines.
SPECIAL NOTE to our customers: This is a flow matched set of Fiveo fuel injectors. Viton orings and connectors are supplied for installation in modified S2000 2.0L 4 cylinder engines (EV6/Keihin adapters supplied).
This injector set is sold with a money back guarantee. If you are not 100% satisfied we will exchange or refund your purchase price for returned, unused and uninstalled fuel injectors. You pay only the shipping.
Injector Body Design: Metal and composite plastic
Flow rates:
This set is flow matched to within 0.5 to 1.5%
We use the industry standard Heptane as our testing agent.
1000 cc/min at 43.5 psi (3 bar)
Dead Time: 0.75 ms at 14 Volts
(Complete flow data sent with each set).
This fuel injector will function at rail pressures in excess of 100 psi, 7 bar.
Excellent low pulse width response with predictable response down to 1 ms.
Excellent atomization for modern multi-valve engines.
Injector type: Filterless, EV14
Application: Super-street and racing, naturally- and forced-aspirated engines.
Fuel Delivery: Single-hole, modified disc
Electrical Connector: U.S. CAR
Spray type: wide cone, maximum atomization
Length: 2.5 inches, 62 mm
Diameter: 19 mm
Orings: Top and bottom, Viton
Resistance: 11.8-15.5 Ohms (12.5)
Fuel types: All type gasoline, Methanol, E85, E25, E10
4 Wired, two ended electrical connector adapters, included.
We are fuel injector experts - email with your questions.
All injector sets are sold with our 36 Months/Unlimited Miles Warranty.
We adhere to the latest technology and craftsmanship techniques.
Old Jun 22, 2011 | 12:57 PM
Suzuka_Joe's Avatar
id725's and id1000's are tried and true. only injectors i'd buy. Call T1 race development and get a set
Old Jun 22, 2011 | 01:08 PM
Wydget's Avatar
I've already searched around and FULL BLOWN has the best price on ID's. But they also offer bosch 1000cc's that are supposed to be identical to ID's. I just came across these and figured I'd get some opinions on them...
Old Jun 22, 2011 | 01:53 PM
Corey Maurer's Avatar
IDs is all I would ever run
Old Jun 22, 2011 | 02:30 PM
Chris@NLM's Avatar
We have had a few subaru's here with them and they were junk.
Old Jun 22, 2011 | 02:44 PM
Wydget's Avatar
Good to know.
Old Jun 22, 2011 | 03:24 PM
siadam's Avatar
Agreed.
Sent from my iPad2 using Tapatalk
Old Jun 22, 2011 | 05:53 PM
GoOn3's Avatar
The ID 1000's are modified bosch injectors! That is even how they were marketed when they first came out. The modified Bosch injectors that LJ (Full Blown) has that are the best bang for buck and match/ are the ID 1000cc injectors without the added price!
Go with LJ, he is a great guy and has the best deals!
Old Jun 22, 2011 | 06:11 PM
Wydget's Avatar
He does have the best deals, I've gone through him for a lot of parts...
Old Jun 22, 2011 | 07:38 PM
DFWs2k's Avatar
Whichever company you deal with the most will hopefully give you the best prices. I requested a quote from fullblown for a few things and it was a couple hundred more than t1 quoted me. Needless to say, ill just stick with t1.
