Flashpro Wideband
Old Dec 21, 2012 | 03:17 PM
jdrsxtypes's Avatar
Default Flashpro Wideband
I installed my PLX wideband today using the ECT2 wire which I cut and crimped the wire out of the ecu to my analog wire out of my wideband unit. Then I tapped the radio wire for the power supply to the wideband unit. Then I went back in flashpro and enabled the ECT2 sensor. Now I have a check engine light stating ECT2 voltage to high.
Old Dec 21, 2012 | 07:30 PM
Manny2587's Avatar
I believe you have to disable the ect2 sensor and then go into the wideband or lambda tables and enable the wideband input as ect2.
Old Dec 22, 2012 | 03:39 AM
jdrsxtypes's Avatar
So I am to leave ECT2 dissabled in the misc section.
Old Dec 22, 2012 | 07:24 AM
Rubn1out4GudLuk's Avatar
When you do make sure you warm your car up real good otherwise it will throw a CEL and register as coolant not reaching desired temp. Just make sure you have at least 4 bars before you go driving and full 8 bars before you rev it past 4K.
Old Dec 22, 2012 | 10:04 AM
Manny2587's Avatar
Yes leave it disabled in misc section. Then select ect2 as your wideband input
Old Dec 22, 2012 | 12:38 PM
jdrsxtypes's Avatar
I was able to get it working now. But the wideband is reading about a point leaner than my factory. I do know that you are also to ground the wibeband to the point of were the ecu is grounded and I do not know were that is. If you know were that is can you let me know or if you found a spot that works good for you as well.
Old Dec 22, 2012 | 02:25 PM
Manny2587's Avatar
It's the ground on the rear of the engine, near the firewall.
Old Dec 22, 2012 | 07:09 PM
jdrsxtypes's Avatar
How the hell do you get to that with out dropping the trans or pulling the motor.
spapdx
Mar 22, 2016 07:47 PM
s2000ellier
Jan 15, 2015 04:18 AM
crisskro
Oct 9, 2013 07:46 AM
crisskro
Oct 7, 2013 01:24 AM
