flywheels with FI ! help?
Old Aug 29, 2011 | 10:24 AM
S2KCHRIS305's Avatar
Default flywheels with FI ! help?
hey guys so ive been looking around the forum and i cant find a clear answer to my question . i am gonna be on boost soon and im gonna change out my clutch system . this is the setup i got in mind . act HD pressure plate , act HD clutch disk , F1 racing 10.75lb flywheel . what you guys think ? what you guys think about the flywheel ? is it to light or should i go with a ap1 flywheel instead ? i got a ap2 and i hate the high rpm hanging i get with my ap2 flywheel . also im installing a greddy turbo kit and i wont be making anymore than 300hp . so what you guys think ? thanks
Old Aug 29, 2011 | 10:39 AM
s2000442's Avatar
I have the ACT setup with 11lb flywheel and I have noticed any difference in driveability vs ap1 flywheel. I am very happy with the choice and I am sure you will be. The issue guys have tends to be with the ultalight flywheels like 8lbs
Old Aug 29, 2011 | 10:43 AM
japhethwar's Avatar
I use a competition 11lb flwheel and a stock clutch and i'm running a good bit more power than a greedy kit. I had a competition iron man clutch but i got sick of the noise and chatter. the stocker is holding just fine for now. Lots of people run the act clutches but i'd def get a stock disk if you like it smooth and quiet. As far as the flywheel goes, the lighter the better in my opinion. Others may disagree but I see no advantage to more rotating mass.
Old Aug 29, 2011 | 10:50 AM
Deception's Avatar
11lb vs 13lb you wont feel a difference most likely... heavier flywheels put more load on the motor which builds boost faster IIRC, not worth paying $300 when Ap1 flywheels can be had for $50
I ran a 7lb fidanza (stock was 15 i think) on an MR2 & honestly it did not make any noticeable difference performance wise, it just made the car easier to stall out from a stop
Old Aug 29, 2011 | 11:44 AM
On my previous s it was a ap1 . And when I switched my flywheel to the f1 10.75lb flywheel. Wow what a difference. It was so quick n responsive . But is 10.75lb to light for boost?
Old Aug 29, 2011 | 02:42 PM
s2000442's Avatar
No I have 11lb flywheel and no issues whatsoever
Old Aug 29, 2011 | 04:37 PM
s2000Junky's Avatar
The lighter the better, if your looking for all out performance. You can learn to drive anything on the street if your having fun is my thinking
I run a ap1 flywheel right now, but this was after 5 years on an 8lb flywheel, half of that time was spent on my f22. I prefer the 8LB on that motor becuase its so lively, but at the time I needed a flywheel in a pinch and ended up with the AP1(Which is a good compromise compared to the 22LB ap2) Next time I open her up its a 8LB again.
Old Aug 29, 2011 | 07:13 PM
camuman's Avatar
Ap2 flywheel sucks. Ap1 best bang for buck. I run one on my ap2.
Old Aug 29, 2011 | 09:43 PM
Imma stick with the f1
Old Aug 29, 2011 | 10:56 PM
Suzuka_Joe's Avatar
f1 = ebay. get a better brand, findanza or act... I've got the exedy hyper single and it has a smaller diameter clutch and flywheel that is around 8lbs i believe. it revs alot better than my ap1 did. i wouldn't have any other setup. when my hyper single dies i'll replace it with another or the carbon clutch they offer
