FMIC with a S/C
Old Oct 11, 2007 | 11:09 AM
  #41
WashabiS2K's Avatar
there is a potential loss in boost, but from some information given to me by a local tuner, the power from cooler intake temps should compensate for the power loss by boost.
Old Oct 11, 2007 | 12:56 PM
  #42
deathsled's Avatar
Everything I have seen indicates that a good FMIC on a SC'd s2000 outperforms an air/water aftercooler consistently.
Old Oct 11, 2007 | 08:45 PM
  #43
Silver S2k4's Avatar
If you have the AC and just want the look then get the front mount radiator from Tech 2. I got about a 15-20 degree drop in temps and you don't have to mess with pipes or worry about boost loss.
Old Oct 11, 2007 | 09:58 PM
  #44
EriS2k's Avatar
Old Oct 11, 2007 | 10:17 PM
  #45
Antonov's Avatar
it really depends what you are using the car for. If its a drag car, you only really care about low intake temps for short periods of time. This is where the air/water setup is proven better. Just put in some ice water. If you do any kind of roadracing or activities that would cause the car to heatsoak the air/air is the way to go.
Old Oct 17, 2007 | 10:30 AM
  #46
WindchaserS2K's Avatar
They don't make that anymore
Old Oct 17, 2007 | 10:51 AM
  #47
mr_grand_prix's Avatar
How good are the Spearco intercoolers for superchargers..?
Old Oct 18, 2007 | 11:30 PM
  #48
the__j__factor's Avatar
i have no idea what and after cooler is, but i have FMIC with my rotrex and no joke my intake temps never go above like 24degress on a hot day (28ish degrees)
...unless i sit in traffic for a long time lol, even then the thermal fans come on and everything cools down straight away.
Defiantly recommend them!
Old Oct 23, 2007 | 02:23 AM
  #49
808style's Avatar
has anyone confirmed that this will work with the vortech kit?
Old Oct 23, 2007 | 06:19 AM
  #50
I just had a quick search for a pic of the vortech kit, is it just like the one below?
If so intercooler would work fine IF you can clock ur s/c and point the output down or to the left.
If you cant it looks like ud have to run pipe work going in and out of the intercooler from the right hand side, something like the pic below
Hope that helps a bit, also one last thing most intercoolers rate the pressure drop per due to the intercooler, usually its something tiny like .6 psi at 15psi or something.
