ford 8.8 lsd
Old Feb 11, 2014 | 04:31 AM
hondabim's Avatar
Default ford 8.8 lsd
hello guys
need held, just rebuilt my 8.8. I went to 4.3 from a 4.1. I track about twice a month and drift some times.it is a kind of dd car at 500 hp
I need a nice lsd, what do you have'?
thanks
Old Feb 13, 2014 | 05:54 PM
stantaur's Avatar
Regular Eaton clutch type with carbon discs, cost around $500 from Summit Racing. Works fantastic thanks to running mineral-based Castrol gear oil and Trans-X friction modifier. Two 295mm wide Hoosier stripes from corner exit to next corner entry. :-)
Old Feb 14, 2014 | 08:29 AM
1SlowSi's Avatar
For track use you should only use a Torsen style diff just like the factory uses. You can use a trulok/trutrac as well but the Torsen would perfect better and doesnt use discs.
Old Feb 14, 2014 | 10:32 AM
5thgen's Avatar
The Detroit truetrac is a Torsen style LSD. I was considering this diff, but have been reading that some have issues with "clunking" noise and play in the pinion to axle somewhere.
The main options for the Torsten diffs are the truetrac, ford torsen, and the more expensive wavetrac.
Old Feb 14, 2014 | 10:59 AM
hondabim's Avatar
this 8.8 is such ruff quality product....
anyways, I was thinking about the wavetrac lsd....
Old Feb 14, 2014 | 01:14 PM
5thgen's Avatar
If you go wavetrac, you need to have axles with 31 splines, which would mean custom. I didn't see an option for 28 spline.
Old Feb 14, 2014 | 07:11 PM
herecomesboost's Avatar
I'm happy with my Eaton Posi.
Old Feb 15, 2014 | 05:55 AM
hondabim's Avatar
I have a 8.8 diff 31 spline and fullblown kit
Old Feb 16, 2014 | 06:03 AM
F22Cmarvin's Avatar
^ I have the same with wavetrack LSD and motive gear. Now I just need to find a stronger tranny...
Old Feb 17, 2014 | 02:36 PM
Prokaw875's Avatar
thought the full blown kit uses 28 spline...
