fuel guage
what can be in the tank that could prevent the gauge from working after the 3/4 mark?....ive been having a issue with my guage since my twin pump hanger install last year ive put in 3 diff sending units i know the guage work when the hanger is outside the tank but once its in i have a issue. i thought i fixed it last week but it turns out that after 3/4 of a tank it stop moving...any thoughts?
im sure you have already done these things but I would start here:
-shine a light from the top to see how the socks should line up.
-make sure the way the hanger is turned that the socks match how it should look after shinning the light down in there.
-put a couple degrees of angle from the float and the socks instead of straight in line. that helped me a bit.
-see if the float device (the black floatie thing) is turned the right way.. sometimes it gets caught upside down and will show more gas than you actually have.
gl man... seems like everyone goes through hell with the dual hanger. :/
Mine doesn't register at all now.. It's showing fuel light on and no fuel. Been driving according to how many miles I get out of a tank which has been a total PITA!
Hurt my back at work a few weeks ago and have not had the patience with a sore back to attempt to fix it.
Will let you know how the fuel gauge goes when I get into it!
Hey man, I will be away on my honeymoon for a month to Greece, when I get back I will start work on the car again. Discovered Afew little oil leaks on the oil filter relocation block. So looks like I have some work to do when I get back.
