Fuel injector popped out
Old Aug 28, 2012 | 07:44 PM
eastonh477's Avatar
Default Fuel injector popped out
so after doing a hard pull my car reaked of gas and started bogging. i pulled over shut off and popped the hood to find fuel everywhere. I start the car again and see the fuel just shooting out of the bottom of the fuel rail on the first cylinder. somehow the injector shot down into the whole more and unsealed from the top. did i miss a step on the install. I just swapped injectors, did i need anything else. this has me worried as my car could have went up in flames.
Old Aug 28, 2012 | 07:47 PM
9krevvin's Avatar
Post some pictures if you can. That way we can really see what happened.
Old Aug 28, 2012 | 08:45 PM
hybridsol's Avatar
Used BOTH cushions right? (1 stock, 1 with injector kit)
And yes, that is scary!
Old Aug 28, 2012 | 08:55 PM
Corey Maurer's Avatar
Glad nothing bad happened man! post up some close up shots so we can get a feel for what happened
Old Aug 29, 2012 | 07:00 AM
eastonh477's Avatar
well i put it back together so i cant really take a pic unless i blow it again loll. and i think thats my problem hybridsol im only running the stock seal. that prob why it dropped down into the hole more. and yea corey it was good seeing you at wekfest ill try to snap a pic of my injector settup
eastonh477's Avatar
and thanks for the help guys
Old Aug 29, 2012 | 11:57 AM
You deffitly need to run 2 seals they but up against each other
Old Aug 29, 2012 | 12:23 PM
miguel329's Avatar
2 seals? Im using one on each side since last sept no issues...i have id1000. But good reminder to car fire exstingisher in car, i have a full size one in my trunk lol.
Old Aug 29, 2012 | 12:28 PM
herecomesboost's Avatar
https://www.s2ki.com/s2000/topic/862...-install-help/
Old Aug 29, 2012 | 10:17 PM
Forcedbird's Avatar
Don't forget to remove the fuel rail mounting studs and install the 3 metal washers if you have the ID injectors.
