fuel pump not priming.
Old Jan 9, 2013 | 11:59 AM
codybjag's Avatar
Default fuel pump not priming.
finally finished the car went to start it and i heard nothing from the fuel pump strange. i checked the fuel pump fuse it was fine. could it be the main relay or the ignition fuse? help please
Old Jan 9, 2013 | 12:25 PM
S2K-F8's Avatar
Older Aeromotive 340's needed to be wired "reverse polarity". Is it a new pump or older version? Did you wire it regular or reverse?
Old Jan 9, 2013 | 12:41 PM
codybjag's Avatar
it worked before i replaced my head and boom dosn't work any more i'm pretty sure i have everything plugged in ready to go.
Old Jan 9, 2013 | 01:09 PM
S2K-F8's Avatar
Gotcha, sounded like you just put in a new pump so that was my first thought (since I found out the hard way)...did you make sure you hooked up the ground wire that attaches to the back of the head?
Old Jan 9, 2013 | 04:20 PM
codybjag's Avatar
ugh the ground that attaches to the airpump? i might not of if its not that one lol
Old Jan 9, 2013 | 04:47 PM
S2K-F8's Avatar
I dont think its the same one.
Old Jan 9, 2013 | 05:25 PM
codybjag's Avatar
well that might be my problem. do you know where it is? or do you have a picture of it?
Old Jan 9, 2013 | 05:27 PM
codybjag's Avatar
nvm i found a picture of it.
Old Jan 9, 2013 | 09:21 PM
codybjag's Avatar
problem fixed you were right if i ever go snowboarding ill buy you a beer good sir. thank you.
Old Jan 10, 2013 | 01:01 AM
S2K-F8's Avatar
No prob bud, glad to help
Are you in CO? If so, what part?
Scott-
