fuel pump with UR kit?
Old Aug 11, 2007 | 11:07 AM
billybobxxx's Avatar
Default fuel pump with UR kit?
hi,
just want to know if i have to upgrade the fuel pump with an ultimate-racing kit? the kit doesn't come with a fuel pump but have 600cc injectors in it.
just to be sure
thanks
Old Aug 11, 2007 | 12:06 PM
Dsgs2k3's Avatar
u should
Old Aug 11, 2007 | 06:43 PM
Reborn56's Avatar
Yes you need to
Old Aug 12, 2007 | 05:33 PM
ok, but my a/f ratio gauge doesn't indicate that i am lean....always stay in rich part of the gauge even at 8psi...
why i should have a fuel pump if the OEM is ok??
Old Aug 13, 2007 | 09:45 AM
hokies2000's Avatar
If you're reading A/F ratio off the O2 sensor you may not be getting the whole picture. The stock O2 sensors bottom out (they're only designed to read a certain voltage range). You need wideband to truely know your A/F ratio picture.
Old Dec 19, 2007 | 06:41 AM
CIVICTOS2000's Avatar
Bump OP...
Old Dec 19, 2007 | 06:44 AM
I'm in the same boat... any comments?
D.
Old Dec 19, 2007 | 02:57 PM
Envied's Avatar
The way you should look at it with FI is.. The more prepared the better. You may not NEED the extra flow of fuel from the pump at your current boost level, but why strain the oem pump to where it could cause failure. Might as well upgrade it to avoid a pesky problem that you will have to troubleshoot down the road..
Old Dec 19, 2007 | 03:12 PM
Soul Coughing's Avatar
100 dollars and a few hours to pull the tray and you have a bulletproof fuel system. I don't see why you wouldn't do it...
Old Dec 19, 2007 | 03:58 PM
Just what I wanted to Hear..now I just have to find which one I should use.... Thanks guys.. ^^^^
D.
