good work! maybe in the market for one of these soon
Ok, so I did some searching.... and for NEW it all adds up like:
Stage 3.9 Kit which is rated to 600hp $2695 Ford Racing M-4010-A88 (aluminum) carrier $299 (http://www.jegs.com/i/Ford-Racing/39...oductId=762991) FORD 8.8" 28 SPLINE REAR DETROIT TRUETRAC POSI 912A562 $470 (http://www.ringpinion.com/ProductDet...and=Eaton_Posi) (Above is NOT to be confused with Trac Loc which go for $270) 3.9 or 4.11 gearset $140 (ebay) Installation kit (?) say #120 Total $3724 Assuming any reasonable shop could assemble the diff, how difficult is the install? New wheel bearings needed? Other stuff? |
you can reuse the stock wheel bearings.
god this is nice. but the timing for me sucks!
u dont wanna use an aluminum case, u want the steel one, aka not the one on jegs
Originally Posted by 2ndTimeAround
(Post 20667906)
Nodular iron not steel. If you want a diff for the track you want this one: http://www.dpiracingproducts.com/sto....php?cPath=4_5
What's the reason for the DPI diff costing 2x say a T-2R, how much abuse it can take? |
One of these kits + this box: https://www.s2ki.com/s2000/topic/846...ntial-gearbox/
would provide a lot of win (and bankruptcy) |
u can get a steel or iron one for next to nothing at a junk yard, and that quaife transmission is beautiful
Originally Posted by hybridsol
(Post 20667634)
Stage 3.9 Kit which is rated to 600hp $2695 Ford Racing M-4010-A88 (aluminum) carrier $299 (http://www.jegs.com/i/Ford-Racing/39...oductId=762991) FORD 8.8" 28 SPLINE REAR DETROIT TRUETRAC POSI 912A562 $470 (http://www.ringpinion.com/ProductDet...and=Eaton_Posi) (Above is NOT to be confused with Trac Loc which go for $270) 3.9 or 4.11 gearset $140 (ebay) Installation kit (?) say #120 Total $3724 Assuming any reasonable shop could assemble the diff, how difficult is the install? New wheel bearings needed? Other stuff? Stage 3.9 Kit which is rated to 600hp $2695 Ford 8.8 28 spline diff (junkyard- any diff) $50-$100 (cast iron, not alum) 4.10 gearset $140 (Richmond gear http://www.summitracing.com/parts/RMG-SFD8806/) Installation kit $150 (I couldn't find the exact part at Summit or Jegs, but simillar) Differential rebuild 4 hours @ $80/hr = $320 New wheel bearings- why not at this point 2 x $60 = $120 (http://www.hardtopguy.com/store/prod...7&cat=0&page=1) AND: FORD 8.8" 28 SPLINE REAR DETROIT TRUETRAC POSI 912A562 $470 (http://www.ringpinion.com/ProductDet...and=Eaton_Posi) or (http://www.summitracing.com/parts/DTL-912A562/) -or- 8.8 FORD PLATINUM TRACK DIFFERENTIAL - 28" SPLINE $840 (http://www.dpiracingproducts.com/sto...products_id=34) *Installation by owner* Total $3995 - $4365 It's exessive, and that's why I like it! |
1 Attachment(s)
Trying to decide on 4.1 or 3.9, do these numbers look right for an AP2?
I just copied them from the gear comp table in KManager, 50mph in 1st seems high to me. Attachment 202645 |
| All times are GMT -8. The time now is 04:42 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
