Full Blown Ford 8.8 Rear End Kits!
Old Jan 4, 2013 | 08:55 PM
  #171
mr-pitts's Avatar
I though they had a good reputation?
Old Jan 4, 2013 | 11:17 PM
  #172
5thgen's Avatar
Bolts look like a m12 x 1.75. About 26-27mm thread length.
Ford part no.
N800594S100
Old Jan 5, 2013 | 04:21 AM
  #173
mr-pitts's Avatar
Thank you, I think the diff bolts ar 7/16 unc, I bought 7/16 unf but found needed unc.
The studs are M10, I'll order some m10/1.75 and see how I get on, thanks again.
Old Jan 6, 2013 | 07:22 AM
  #174
1SlowSi's Avatar
The one part I can agree with you on is that these kits should include every bolt needed to make this a "bolt on" kit. For the price, it doesnt make sense that something as little as 4 bolts aren't supplied with the kits.
Old Jan 6, 2013 | 07:40 AM
  #175
bruthaboost's Avatar
I'm with you. If anything is advertised as complete and bolt on, it should be precisely that. If it was 100 dollars and wasn't complete, I'd still have a problem. This appears to be a Full Blown QC/QA issue and they need to fix it.
Old Jan 6, 2013 | 07:47 AM
  #176
s2kt3's Avatar
looks like I will NOT be purchasing this in the near future, for that kind of money I would expect perfection. damn !
-Lee
Old Jan 6, 2013 | 08:05 AM
  #177
sohc_mshue's Avatar
i was a bit annoyed as well that it did not have the bolts for the pinion flange. It sucks realizing at the last minute that i did not have the bolts i needed. Luckily i had a f150 at work i borrowed some bolts from.
I did not have the other issues you have though. Hopefully Full Blown will help you get them worked out.
Old Jan 6, 2013 | 09:19 AM
  #178
sata3000's Avatar
Sent from my Galaxy S II using Tapatalk
Old Jan 6, 2013 | 04:20 PM
  #179
WootRWD's Avatar
My brackets came with bolts...... Are you guys referring to the bracket bolts?
Old Jan 7, 2013 | 06:34 AM
  #180
1SlowSi's Avatar
The bolts we are talking about are for the companion/pinion flange to bolt to the driveshaft. If the kit utilized a "universal" mount to multiple pinion flanges then I could understand not including them but this isnt the case. This is by no means a bash fullblown thread but more of a "come on guys, its only 4 bolts extra to throw in". haha.
