Fusebox relocation without extending wires?
Old May 13, 2015 | 11:44 AM
S2KCHRIS305's Avatar
Default Fusebox relocation without extending wires?
Like the title states. has anyone relocated the fusebox without having to extend wires? can it be done? im confused on which route to go on relocating my fusebox. What you guys think?
Old May 13, 2015 | 01:10 PM
staylor725's Avatar
If your putting the fuse box behind the fender you must extend eps power steering wires.
Old May 13, 2015 | 01:41 PM
I was thinking of relocating to inside the cabin in the passenger footwell, though by the looks of it, il need to extend wires there also. Any other location where wire extension isnt needed?
Old May 13, 2015 | 03:14 PM
staylor725's Avatar
I think your only option is to turn it sideways and you won't need to extend any wires but you can still melt it. What manifold do you have? Why don't you want to extend wires?
Old May 13, 2015 | 03:23 PM
Im running pfabs front facing manifold. im worried to run into connection issues with the wires being extended, its my first time doing this. not sure where to relocate the fuse box, either passenger footwell or fender
Old May 13, 2015 | 03:31 PM
staylor725's Avatar
I have done this on my car and a friends we both have no problems. Just make sure you use good wire, solder and heat shrink all connectons. I recommend doing it behind the fender but face the fuses to the wheel so if you need to get to it, you can just remove the wheel and half the fender liner and replace fuse.
Old May 13, 2015 | 03:57 PM
is drilling required? I do not like the idea of drilling into the car. what needs soldering? I thought it was just extending wires
Old May 14, 2015 | 06:39 AM
staylor725's Avatar
Yes drilling is required, you should solder and heat shrink the wire's that your extending for the best connection/protection.
Old May 14, 2015 | 07:57 AM
So when going to the fender drilling is a must, there's no other way around that? instead of soldering, butt connectors done right wont do the job? Ive never soldered before, but have delt with butt connectors for stereo systems and such.
Old May 14, 2015 | 08:04 AM
staylor725's Avatar
Your going to have to drill mounting holes to hold the fuse box, butt connectors will work but i have seen them come loose.
