Gauges
Old Apr 17, 2008 | 09:26 AM
USMCAP1's Avatar
i run the AEM serial guage. There isnt much room in the S2 and i like things as simple as possible, if i want to monitor something else it is as easy as a push of a button. It just looks clean in my opinion and doesnt really attract unwanted ricer attention.
Old Apr 17, 2008 | 12:05 PM
ZSAK's Avatar
also on a side note if i get the serial gauge will i need modifrys temp gauge mod or can use this gauge to monitor it. Do you need to buy anything extra with this gauge to monitor different settinngs
Old Apr 17, 2008 | 12:09 PM
USMCAP1's Avatar
No, i use mine to monitor engine temp. I am pretty sure there is nothing else needed. i had InlinePro install mine with the kit. It's really nice to be able to see temp now
Old Apr 17, 2008 | 01:15 PM
Spec_Ops2087's Avatar
The gauge will monitor the temperature based on the temperature calibration that was set in the AEM EMS. In short, it will work fine without the modifry fix.
To monitor things like oil pressure / egt / other sensors that do not come with our engine stock, you will need additional parts.
Old Apr 17, 2008 | 01:31 PM
ZSAK's Avatar
cool thanks spec, can't wait to have my inline car like you
Old Apr 17, 2008 | 02:13 PM
jwa4378's Avatar
You will need to update the calibration for the coolant temp within the software. PM "timg", I think he has it lying around on some thread somewhere...
Even with this calibration, the OEM gauge will still not work. It will still serve as a warning once temps reach something like 220* (all bars will light up all of a sudden). You will be able to monitor the engine temp via the serial gauge, but the modifry fix I believe is required for the OEM dash gauge to work.
John
Old Apr 17, 2008 | 03:21 PM
RISLAR's Avatar
I use the AEM afr, and a duel oil gauge by SPA, all you need really
Old Apr 17, 2008 | 03:28 PM
ZSAK's Avatar
out of curiousty how hard is it to install the serial gauge and say the uego gauge as well. is it worth having a pro install it or i should be able to do it
Old Apr 17, 2008 | 03:43 PM
Its just like installing any other gauge
Granted, if you don't know how to install a gauge then it might be complicated only because its your first time.
Old Apr 17, 2008 | 04:26 PM
gotswap's Avatar
Flip a switch in the AEM software, set your gauges in the serial gauge software, find na ignition hot wire, find a ground spot and plug the serial gauge into the serial port of the EMS. DUN
Right now I have mine configured to cycle through MPH, water temp, boost, AIT and AFR.
The nice thing about the gauge is it holds min and max values for each parameter and you can set it up to warn for certain conditions like over boost or lean conditions.
