Getting ready to install! turbo
Ok I have my entire setup ready minus a couple of small things. I want to control boost through the aem ems, so do I need to purchase a gm boost solenoid?? Also I need a map sensor 3.5 bar should be fine, any suggestions on what to buy or where??? Thanks
Jason :D |
yes you need the gm boost solenoid and gm map sensor
The GM boost controller and MAP sensor are junk. Spend a little more money and buy all AEM controllers and sensors. You will be much happier in the end. ;)
Aww don't say that.
Originally Posted by afwfjustin,May 24 2007, 08:40 PM
Aww don't say that.
Get the AEM stuff.
I had the GM boost control solenoid and after about ~1500 miles it would no longer control boost. I was over boosting ~16psi with boost set to 12psi in the EMS. Not good. I didn't blow the motor, but it could easily happen. |
Damn that sucks... I was about to order a GM boost control solenoid too. I already have the 3 bar map but it looks like I might have to make some changes.
I don't want to pour any more money into this car!!! :( |
