godzilla/CTSC owners
i am having a second hand godzilla BOV sent to me - do i need to purchase a new flange to bolt this on with, or will it bolt directly to the comptech aftercooler without one?
i have never seen the underside of this BOV. can anybody supply a picture of the bottom of it? thanks :) |
it should bolt on...... i have one somewhere.. ordered for a customer that never bought it. but we have put several on and there was nothing we had to do to AC to make it work.
do i need a flange to bolt this on with, or do i just need the actual blow off valve?
Not the exactly pict you need but you can figure it out. The smaller piece laying flat on the bench with the 4 screws and the clamp screws directly to the a/c after you remove the piece that normally would take the hose directly to CT's bypass valve. It's square under there though you can't see it.
https://cimg7.ibsrv.net/gimg/www.s2k...4420a46952.jpg This piece at the bottom obviously comes off. https://cimg6.ibsrv.net/gimg/www.s2k...bc276f6ef7.jpg Installed. If you zoom in, you can see how it just bolts up to the original holes. https://cimg5.ibsrv.net/gimg/www.s2k...6c8bc460fa.jpg All this (and more) came with the BOV when purchased new. Unless you get half a BOV, you should be fine. :LOL: |
jano, thank you. now i have a clear idea in my head as to how it all works.
the seller showed me a picture of the round flange and i got confused, knowing that the aftercooler piece is square. now it makes much more sense! :) |
one more stupid question...
there are 2 spots for vac lines on this thing! which one do i go with? do i have to plug the other one? i had it working before, now its stuck closed again..... |
the kit had a godzilla BOV on it before. the previous owner just put the stock one back on it. should bolt up no problem. GL.
^^ yea thats the easy part. i got the thing on, i just have too many vacuum options! lol
which one do i go with? top? bottom? both? derrrrrr |
which one do i go with? top? bottom? both? derrrrrr If not,My car won't able to rise up 11.8 psi.GL |
| All times are GMT -8. The time now is 03:10 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
