Well guys the day has finally come. My car has been down since February due to having to replace the block.
My Setup:
Stock f22 Block
Supertech valves,guides, ap2 retainers in the head.
2mm Head Gasket
P Fab log manifold
Precision JB T3/T4 70AR cold side 83AR Hotside
3" Downpipe and straight through exhaust
750cc injectors
AEM EMS
Omni 3Bar Map Sensor
I'm hoping to get over 400 on 91. Wish me luck and I'll update with videos and a dyno sheet later.
Originally Posted by jabbarahm,Nov 12 2010, 03:19 AM
noob question here, what does this mean:
cold side / hot side? sorry and thank you
It is a Precision journal bearing(JB) turbo. It has a T3 (smaller) turbine/exhaust side and a T4 (bigger) compressor/inlet side. They do this with 4 cylinder turbos since 4 cylinders don't flow as much out the exhaust and it helps spool and make bigger power than a straight T3 turbo.
