Got my New Map Sensor!
Old May 2, 2008 | 09:09 PM
EriS2k's Avatar
Default Got my New Map Sensor!
OEM LOOKS FTW!
Old May 2, 2008 | 10:26 PM
AusS2000's Avatar
Niiiice! Now, how do you integrate with the EMS.
Old May 3, 2008 | 05:08 AM
PeanutButter's Avatar
Yeah, are you using EMS?
There isnt a setting in it for the Omni
Old May 3, 2008 | 08:27 AM
Shftat9k's Avatar
You use the wizard and enter the proper voltage parameters. When I spoke with Omni about it they told me they would walk me through the process.
Keep us updated! I should be ordering mine within 2 weeks or so.
Old May 3, 2008 | 10:42 AM
EriS2k's Avatar
I will be Using Aem EMS with Uego!
The EMS does not have the option for the OMNI MAP, but you can enter the proper voltage to make it work!
I will keep you guys updated!
Old May 3, 2008 | 11:50 AM
jwa4378's Avatar
Let me know what parameters you have to enter into the EMS. I was going to use a GM 3-bar MAP, but that one is not plug-n-play like this one advertises... If it will screw straight down into the OEM location, it would be worth it.
John
Old May 3, 2008 | 11:57 AM
Did you just buy it for the function of putting it on the stock TB, or did you get it to run 43 psi of boost
Old May 3, 2008 | 01:50 PM
XclusiveAutosports's Avatar
I'm subscribing for future use.
I'd like to know the exact settings for the EMS to function with that map sensor.
Old May 3, 2008 | 02:03 PM
EriS2k's Avatar
I Bought it cause i'll be using AEM EMS, And you Cant Use Stock Map cause it will not Support Boost!
Old May 3, 2008 | 02:04 PM
EriS2k's Avatar
As soon as i get my Car Tuned i will tell you the exact Voltage Parameters for that MAP SENSOR!
i got you guys dont worry!
