Grams 1000cc fitting woes
Old Nov 9, 2014 | 08:04 AM
zittymchoop's Avatar
Default Grams 1000cc fitting woes
Hi!
As topic reads, im trying to install some new injectors and have come across a few issues. I want to make sure that I dont have the wrong parts. Its come as part of a kit.
But I cant seem to make them fit as they are. The top o ring is considerably larger than the stock one and the length when placed in the rail is also longer than stock, meaning ill be unable to bolt these down without some sort of spacer.
What do you think?
Old Nov 9, 2014 | 08:51 AM
SaskCRX's Avatar
Is your car AP1 and the kit is for AP2? The grams injectors look the same as mine and installed with ease on my 06
Old Nov 9, 2014 | 09:16 AM
Ap1....
Old Nov 9, 2014 | 04:42 PM
s2klariat's Avatar
I'd bet you have the Ap2 injectors.
Old Nov 11, 2014 | 02:01 PM
KraftWerks's Avatar
Former Sponsor
Can you measure the top of the injector? Not the o-ring but the actual injector where it would slide into the rail?
From the picture, it looks like the machined injector, only with the standard 14mm o-ring which could be the case.
You can PM me or email me as we'll and either way, I'll get you sorted.
cjweidl@group-a-eng.com
Old Nov 12, 2014 | 07:16 PM
jpetch05's Avatar
Yeah u need top hat adapters. Those are 11mm stockers. You have grams with no adapters making them a 14mm or ap2 fit.
gst19psi
Apr 8, 2014 10:23 PM
s2kseven
Jun 14, 2011 07:47 AM
Devinb
Feb 24, 2011 09:28 AM
Kyushin
Oct 21, 2009 04:10 PM
The Gent
Jun 3, 2009 10:05 AM
