Greddy E-manage
Old Jul 24, 2006 | 08:07 AM
TheBlack01's Avatar
Default Greddy E-manage
a buddy of mine has i belive a 05 civic si. He just installed a turbo kit and took off his e-manage system he has that with 440 injectors and he said he would sell it to me if i would fit. so dose anyone know if it will work ? also what are the stock injector size on the S2000
Old Jul 24, 2006 | 09:19 AM
CaptKirk's Avatar
You might wanna research in the FI forum... They are the ones that usually need to use such things and would have more knowledge...
Old Jul 24, 2006 | 11:46 AM
Nandska's Avatar
moved to FI
Old Jul 24, 2006 | 12:08 PM
d-j's Avatar
d-j
Which model Blue or Ultimate?
Old Jul 24, 2006 | 03:19 PM
Slows2k's Avatar
A blue can work fine to run 440's. As long as you don't want over 350whp.
Stock injectors on a AP1 are 360-370 cc/min depending on the flow sheet you want to believe.
Old Jul 24, 2006 | 04:04 PM
TheBlack01's Avatar
so if it is a blue i wanna put the 440's in or leave my stock?
Old Jul 24, 2006 | 04:12 PM
TheBlack01's Avatar
and would it be better if it was the Ultimate
Old Jul 24, 2006 | 04:31 PM
MugenRioS2k1's Avatar
The ULT is crap
https://www.s2ki.com/forums/index.ph...f=142&t=331737
Old Jul 24, 2006 | 04:36 PM
TheBlack01's Avatar
so if its the blue should i get it would it be worth the money or just put it towards somethin else
Old Jul 24, 2006 | 04:37 PM
Slows2k's Avatar
The Blue has worked on SC'd cars and some low boost turbo cars. Myself and AusS2000 both have used the Blue E-manage with 7-8psi SC. Wesmaster used a Blue with a 7-psi Speedcraft, along with many users of the UR turbo with the E-manage.
There isn't much point to using the E-manage with a NA aplication, A VAFC will give the same results, be less work to wire in, and have more flashing lights.
