Greddy E85
Originally Posted by dsddcd,Oct 21 2008, 07:49 PM
I pray it doesn't get more popular. You pay less for the fuel / gallon but it is less efficient so you will need to add 30-40% more and you pay more for grains and meat. I say do it right and more to LNG / Propane it is soooo much better.
If you want efficient, buy a civic...
Originally Posted by AndyFloyd,Oct 21 2008, 06:59 PM
the impressive thing ( for other greddy owners ) is that its holding 14psi to redline. Looks like the turbo might have a little more than 10psi in it afterall.
Originally Posted by s2kadl,Oct 21 2008, 07:04 PM
Thats what I was so happy about. 14psi and its still holding so well. Tuners did say that the turbo is nearly at its peak, probably a couple psi left, the next mod to make some more would be bigger turbo but Im happy with it like it is for now.
It must be a blast to drive. You may need to check your wheel alignment if the car get taily with the power delivery. I think the UK wheel alignment spec will be good for your driving style.
This dyno is ultra conservative! My car with a vortech at 7psi got 200+rwkw on the dynodynamic. Dyno log produces another 10% higher than our dyno dynamic generally, but it really depends on the tuner and their dyno correction factor.
IMHO you can get around another 4psi on your setup but enjoy this first before you want more
You can see that the torque curve tappered off at the top end. This is possibly from the short waste gate pipe which can cause some exhaust turbulence and the small turbo. You might have gained more top end power if you lengthen this pipe longer than 40cm. Some food for thought when you want to change your turbo
Yes the E85 will use more fuel to make more power. However you will use less throttle at cruising speed from the increased in power. Most people reported similar and some even cheaper petrol bill
I am still waiting for the petrol in Queensland eventhough most of the sugar cane for the ethanol comes from this state
Thanks H9krpm! Thanks for all of your help and suggestions. Made the journey a whole lot easier! Cant wait to see your gains when you guys finally get the fuel.
Will definitely look into a modified dp down the track. I got plenty for now, rear end gets all "taily" even in third when boost hits. Will have to get my alignment done for sure.
Woops, yep got a divider plate welded into my DP, forgot I even did that!
They've been so slow. As a matter of fact automotive things are a lot slower up here than the good old Adelaide
Mark, can you do me a favour and check your fuel consumption with the E85 mate? I will give you a call this weekend buddy
