Greddy emanage blue vs ultimate
Old May 14, 2008 | 03:32 AM
chillout18's Avatar
Default Greddy emanage blue vs ultimate
I'm a newbie to this section of the forum so Im trying to gain more knowledge. I was wondering what are the main differences between these two. I trying to put together a basic turbo kit that I wont be boosting over 10 psi. I just realized they had 2 different versions of emanage. will the blue be sufficient? also will the emanage allow be to pass emissions or does it disable the obd2 port?
Thanks guys
Mike
Old May 21, 2008 | 03:46 AM
chillout18's Avatar
bump..... still need help
also what accessories/options would I need to get with either. and do both support only up to 550 injectors?
thanks
Old May 21, 2008 | 06:06 AM
devs2k's Avatar
ultimate > blue
you will pass emissions with the ultimate
is this for a s/c kit?
Old May 21, 2008 | 06:55 AM
chillout18's Avatar
turbo kit....why would the blue not pass emissions....
do you know the answer to any of the other q's
thanks btw
Old May 21, 2008 | 06:59 AM
devs2k's Avatar
thanks btw
the blue will pass emissions it's just not as good as the ultimate
at the very least you will want the emanage ultimate; AEM EMS/ kpro maybe on how much power you seek to make
which turbo kit is this?
Old May 21, 2008 | 07:07 AM
devs2k's Avatar
the blue only has the ability to increase the injector pulse width; the only way you can decrease the pulse width with the blue is is by lowering the MAP values the ECU sees
the timing retard/advance control isn't the most accurate, and therefore timing might bounce around a lot
the emanage ultimate can control timing better and increase and decrease pulse widths
Old May 21, 2008 | 07:08 AM
chillout18's Avatar
the e_auto kit in the sponcers section....i'm just trying to seewhich one will suit me best I won't be going for hig hp numbers just want something reliable with extra power... I thought the blue woul b enough since greddy kits come wit them but I don't realy know what the difference is
Old May 21, 2008 | 07:11 AM
devs2k's Avatar
[QUOTE=chillout18,May 21 2008, 11:08 AM] the e_auto kit in the sponcers section....i'm just trying to seewhich one will suit me best I won't be going for hig hp numbers just want something reliable with extra power...
Old May 21, 2008 | 07:53 AM
chillout18's Avatar
im looking to get around 300 to the wheels and I was going to use 550 injectors because I thought the blue doesn't support anyting higher
Old May 21, 2008 | 07:55 AM
devs2k's Avatar
why not the greddy in that case, if you want 300 and you are happy there and no higher...
