GReddy eManage- OBDII accessible?
Old Jun 30, 2009 | 11:33 AM
T34418L31's Avatar
Default GReddy eManage- OBDII accessible?
I'm coming from DSM's, where I ran DSMLink.
I've looked at several S2000's with FI, and the norm seems to be to run AEM. Problem is, I live in PA, and need to be able to use the plug in OBDII port for emissions testing. Visual inspection won't be an issue, but I need to at least have the OBD port register.
Is GReddy eManage still OBD compliant? Is it a much weaker system to use? From what I've read, it seems as though you can't adjust timing with it due to the COP - this seems like it'd be a fairly big problem.
Any suggestions on the GReddy or other kits that might work?
Old Jun 30, 2009 | 11:39 AM
suprmonky73's Avatar
where in PA are you from?
im from philly and the only person around who will tune Greddy EMU is PTuning in Manassas, VA
check out the greddy thread in the DelVal forum, a few have discussed it there
Old Jun 30, 2009 | 12:00 PM
JoeyBalls's Avatar
P-Tuning is the only place I would trust with the E-Manage. I drove down there to VA twice from NJ
Old Jun 30, 2009 | 02:32 PM
T34418L31's Avatar
I would just tune it myself? I just need the support tool, no?
Old Jun 30, 2009 | 02:35 PM
AusS2000's Avatar
Greddy E-manage is a piggy back system. You retain your stock ECU and OBDII port.
And yes, if you know what you're doing all you need is the support tool.
S2Kstuntin
Aug 17, 2007 09:21 AM
DFWs2k
Feb 16, 2007 11:02 AM
jdnissanz
Jun 17, 2006 10:48 AM
F1fletcher
May 13, 2006 02:26 PM
