Greddy gasket
I need the gasket that goes on the oil return line on the bottom of the turbo. i want to change it to prevent leaks. Can't find it. do i have to email greddy or where can i find one?
looks like the one on the right. I guess its a t25 gasket (thanks caseygw)
its not leaking, i only idled the car for a couple minutes and havn't driven it yet. My brother forgot to put it on and i found it under my car when i rolled it out of the garage to take pictures. If i gotta take the return line off i might as well use a new one
Just go to a local auto parts store and purchase some gasket material and trace that gasket onto it and cut it out. Or buy a large gasket with a similar material that has a large enough area to trace the old gasket onto at the local parts store and do what I said previously. It'll work fine or just use the one you have if its not too damaged.
mine isnt damaged. didn't know if it could be reused. i was going to anyways and change if it leaked but since i have to change it anyways figured i go new.
i'll reuse it and watch for leaking
