Greddy T518z Now a hybrid T620z update omg
Old Jan 24, 2011 | 10:23 AM
Kitesurfer s2000's Avatar
Have a local tuner in newmilton inbetween southampton and bournemouth.
Old Jan 24, 2011 | 11:15 AM
TRBOKEV's Avatar
Good luck to you on your Greddy adventure. Many of us have been down that path (Although different routes).. We all ended up with different kits though.
I give you three or four months before that Greddy manifold cracks down the center of the merger. Its to be expected with all the extra heat you will be creating due to that horribly inefficient/restrictive manifold. If I were you I would invest in the PFAB replacement.
Old Jan 24, 2011 | 12:37 PM
Torque Obsessed's Avatar
Originally Posted by Tayssti,Jan 23 2011, 07:39 PM
Also, i would just run the greddy manifold IMO. I was debating about haveing a custom EL one made similar to P Tunings mani , but decided on only doing it if the greddy one eventually cracks. The design of the greddy log isnt that bad compared to some other logs although the runners are kind smaller diameter but It at least has a mini collector so the exhaust gases arent running right into each other.
I've been thinking about doing that too. The big difference is that it would make more power at the same boost pressure. The manifold is a limiting factor that could be holding the T518z back a bit.
I also considered asking Pfab to make me a Greddy replacement manifold with a T3 flange instead of T25 (to maximize the benefits of switching to a GT3071R). I suspect that flange limits power too.
I'm really curious to see a dyno chart of this turbo upgrade.
Old Jan 24, 2011 | 12:43 PM
S2Kart's Avatar
Yep my greddy cast manifold cracked down the middle as well, although it took about 18 months. Maybe because I've been cooling down the exhaust side with water/meth injection.
Old Jan 24, 2011 | 01:30 PM
Im really curious to know y the car will not start now there saying its a elec fault like crank sensor but there is not any management lights that have come up.Its almost like when i loaded a new map to try out and the emu dident like it. The tune was going really well the car did a cough from the air filter with what looked like black soot ,they turned it off started it again fine reved it fine all good, then turned it off and it wouldent start .This was at 7psi
Old Jan 25, 2011 | 12:24 PM
Old dyno V NEW
Both at 7psi
New one ownly to 8000.
55whp gain 36 tq gain
Turning the boost up sat now that we found out it was the tuners laptop that was at fault.
Old Jan 25, 2011 | 12:52 PM
I really want to see the dyno results at higher boost! How high will you go?
Old Jan 25, 2011 | 01:02 PM
As high as the tuner can take it you tell me 14 15 16psi?
Old Jan 25, 2011 | 04:02 PM
itlynstalyn's Avatar
I'm pretty sure 14 PSI is usually the safe limit.
Old Jan 25, 2011 | 05:15 PM
Tayssti's Avatar
Keep us posted! Cant wait to see what you make!
