Greddy Turbo Kit Help!
Old Oct 8, 2013 | 11:57 PM
s2kboost951's Avatar
Default Greddy Turbo Kit Help!
I just installed my greddy turbo kit on my 2006 s2000.. im using profab greddy replacement manifold, 550 rc injectors,stock exhaust with cat. oem clutch on hondata flashpro... im on a base map tune...I just bought a hks evc-s boost controller I was wondering if I should get it tuned and boost up to 10psi on hondata flash pro? do I need to get a aftermarket fuel pump? I was looking at aeromotive stealth 340 or walbro 255 fuel pump? will my stock clutch be ok on 10 psi? ...right now car feels laggy and slow at high rpms!
Old Oct 9, 2013 | 12:30 PM
any help???
Old Oct 9, 2013 | 01:00 PM
Jin_SK's Avatar
Installs turbo kit before figuring out what to run on....
A 255 would be advisable, anything beyond that would depend on your goals. Probably not a lot if you're running the Greddy kit. Clutch options, again, dependent on the goal.
And just so you're aware, a basemap is something to get you to a dyno, not to drive (let alone hard). Please get it properly tuned before you trash your car.
Old Oct 9, 2013 | 01:12 PM
Rugby_Guy's Avatar
This is why certain kits get a bad rap. "Greddy kit blew up my car!".... No, street racing on a base map blew up your car. I understand being on a budget, but c'mon, really?
Old Oct 9, 2013 | 01:45 PM
Nyther's Avatar
Beating on the car on the base tune. Probally running pig rich 10.x afrs and flushing the engine... Not the smartest idea....
Basemap is ONLY to drive with PARTIAL throttle to the tuner!
Get the walbro 255 and a 10psi tune and call it a day. Want more power after that, switch tubokit... I also went the same route... But for a DD, you will love it.
youngkilla
Jan 24, 2011 02:46 AM
JoeyBalls
29
Jul 18, 2009 11:33 PM
