Greddy Turbo Owners who have the Profec B Boost
Old Apr 19, 2009 | 04:55 PM
JoeyBalls's Avatar
Thumbs up Greddy Turbo Owners who have the Profec B Boost
What is your desired PSI, what are your settings and do you ever have spiking etc?
Just curious, I am still fine tuning it, these temp swings dont help, I dunno if its better to have a lower SET value with a higher GAIN, or Higher SET value with Lower GAIN
for 12psi I use
Set 47
Gain 5
Set Gain 8
Sometimes it works, sometimes it doesnt, (spike, falling off), but its a "ballpark" figure of 12PSI, I dunno anymore, this is just one more reason why I want a Turbo kit with an external wastegate
Old Apr 20, 2009 | 05:37 PM
JoeyBalls's Avatar
come on
Set=?
Gain=?
Set Gain?
What do you guys got?
Old Apr 20, 2009 | 05:40 PM
THESPY's Avatar
I'll write mine down and post them later.
Old Apr 20, 2009 | 08:15 PM
s2kadl's Avatar
Got mine sitting at around 14 psi
Set: 70%
Gain: 10%
Set Gain: 10
This changes with weather a bit. When it was summer, it required lots of fine tuning and I found that I had to lower set gain quite a bit to avoid spiking. Now that its winter down here, the EBC is behaving itself and allowing me to run a higher set gain. Dont ask me why.
Old Apr 21, 2009 | 04:25 AM
JoeyBalls's Avatar
interesting, I would thing it would be more prone to spike in the winter
I have the SET GAIN to 8, It doesnt seem to make much of a difference in spool time. It holds boost decent, the only problem I am having is with the SPIKING issues, I just dont think I can solve itr other then porting the wastegate, I just dont want to lose my motor to a 14psi Spike, my AFRS are alwasy in check and I do have the METH, but ya never know
Old Apr 21, 2009 | 07:22 AM
Revenge's Avatar
I don't think the spike is as bad as the boost creep but it's still not good, Also the only way to figure out if your really getting a spike is to data log which is what I am tring to figure out. Why not keep lowering the setting until the spike goes away?
Old Apr 21, 2009 | 08:11 AM
Spec_Ops2087's Avatar
it might not, as we've been saying this is a COMMON issue for internal wastegate users. My 100% OEM subaru WRX spikes to 15psi when I floor it then settles at about 12psi and finally 10psi at redline. The only real remedy is a external wastegate...otherwise you just have to deal with it
Old Apr 21, 2009 | 10:25 AM
JoeyBalls's Avatar
Cause when I do that, I only can maintain like 10PSI, I would rather risk Spiking to 13PSI and be able to run at 12PSI, 10-12PSI makes a big difference, as does needing a new motor , but I also cant figure out how to properly set up the E-manage software, I DL it, and plugged my laptop but when I opened it, it asked for a CD for proper installation and I just could'nt get it to work, where did you DL the software from?
Old Apr 21, 2009 | 03:55 PM
asukadc's Avatar
40%
6%
5% right now just did instructed by joey,
CAR IS ****ING INSANE at 95F weather
gotta figure it out when it comes to lil colder tho,
what's everyone's AFR
Old Apr 21, 2009 | 04:04 PM
JoeyBalls's Avatar
I am high to mid 10's by redline, heres my cheesy video where you can see my AFRs, just watch in HQ
[media]uC7g9yHGY38 [/media]
