GT3071R
Old Mar 23, 2009 | 09:59 PM
azunboy's Avatar
Default GT3071R
I got a GT3071R that i picked up for a steal
The turbine side has a 56.5mm diameter wheel...its a 90trim A/R 86 internally wastegated
more info here http://www.turbobygarrett.com/turbobygarre...R_700382_20.htm
Question is where can i locate a hot side that will bolt up to this with a t3 flange?
Old Mar 24, 2009 | 03:23 AM
Revenge's Avatar
Are you talking about a manifold, I am not sure anyone makes a T3 mani without a WG. Greddy does but it's a T25, you may have to go custom, I have also read about welding the WG shut and using an external.
Old Mar 24, 2009 | 08:08 AM
azunboy's Avatar
i believe the turbo has a nissan t25 flanged turbine housing. I wanna change the turbine housing to a t3 or something different if possible
Old Mar 24, 2009 | 08:14 AM
Rollinx25's Avatar
If you need a manifold made call Central Florida Turbo ask for Fernando. Tell him Gabe referred you.
Old Mar 24, 2009 | 09:49 AM
ScorpionT's Avatar
I can get turbine housings. You want a T3 .62 or .82 a/r?
Old Mar 24, 2009 | 09:57 AM
spdracerut's Avatar
http://www.atpturbo.com/Merchant2/merchant...tegory_Code=GTH
Old Mar 24, 2009 | 11:34 AM
AndyFloyd's Avatar
one issue, you have the turbine wheel thats basically a cut down GT30 wheel. Its less efficient and wont work with a T3 housing because the exducer is too small. you would need to have a 60mm GT30 series turbine wheel to make it work with a T3 flanged setup.
Old Mar 24, 2009 | 12:15 PM
DYNOMIKE@AUTOWAVE's Avatar
Exactly what Andy said the turbine wheel is two small for any t3 housing out there that turbo is not a true gt3071 It is a gt3071 that was cut down to be able to be used with a t25 flange housing its a decent upgrade for you greddy guys but still will not have good top end because of the size"to restrictive the hot side"
Old Mar 24, 2009 | 02:06 PM
nextinstant39's Avatar
Dude its cool that you are running a CFT setup and all, but its no reason to post in every thread telling people to call CFT for every problem...calm down a bit.
As far as a housing, try ATP...they may have one.
Old Mar 24, 2009 | 04:03 PM
Revenge's Avatar
If you got a greddy mani could it bolt right up and you could start from there.
