Haltech PnP Connection Problem
Old Sep 14, 2014 | 03:35 PM
CoolGuy094's Avatar
Default Haltech PnP Connection Problem
Have any other Haltech users ever experienced connectivity issues when connecting to your laptop? I can start ECU Manager, plug in, turn the ignition to ON, and hit connect and it will connect. But as soon as I crank the engine it will lose the connection and I can't get it back. I have to restart the software and turn the car back off/on again. Sometimes I'll get lucky and it will stay connected when I crank the engine, but it will lose the connection as I'm driving pretty quickly. Anyone know what's up with this?
Old Sep 14, 2014 | 04:16 PM
baZurk's Avatar
Have you tired another laptop? Just to rule out that issue. Also, make sure you run the haltech tuning program as an Admin, I know that AEM requires that.
Old Sep 14, 2014 | 04:42 PM
CoolGuy094's Avatar
My tuner had intermittent issues with it too on his laptop a few weeks ago. I'll check with my work computer tomorrow.
Old Sep 15, 2014 | 07:17 AM
vader1's Avatar
I have not experienced that, but I have only connected half a dozen times. So it sounds like engaging your starter interrupts the connection. In general, my SC setup runs the coolant pump and fan in my air to water IC, so I am almost always idling the car when I hookup or I drain battery fast.
Are you always using the same cable? I have one USB running from the Haltech under the carpet and coming out behind the seat. If you have something similar then it could just be a bad cable. The cable is the cheapest piece in the chain.
Old Sep 15, 2014 | 07:39 AM
CoolGuy094's Avatar
Yeah I'm the same... Routed the USB from the Haltech under the driver door trim so I just pop the door trim up and there's the cable. If I am connected, no amount of fiddling with the cable will cause it to disconnect. Also, no amount of fiddling with the cable will get it to reconnect after it has lost connection. I suspected the cable at first too, but it seems OK. I checked the connection of the cable to the ECU while I was at the tuner's and it was fine.
Old Sep 17, 2014 | 04:49 PM
haltechmatt's Avatar
Hi Guys - Try swapping the USB cable for a different one. Its probably not a connection problem per se (so no amount of wiggle will cause/fix the problem) more likely the cable shielding isnt doing its job which is allowing electrical noise (maybe from the alternator/charging system) to cause issues. This sort of noise can crash the USB driver which is why you require the software restart to re-establish connection.
-matt
Old Sep 17, 2014 | 05:19 PM
CoolGuy094's Avatar
Thanks for stopping by and offering your advice Matt!
RobertWolfrays
Apr 16, 2015 08:17 AM
s2kseven
Nov 4, 2013 04:07 AM
hondabim
Apr 5, 2010 02:26 PM
CodyLX450
Feb 9, 2009 08:32 PM
formulaofsuccess
Jan 6, 2008 06:49 AM
