Head bolts?
Old Mar 23, 2011 | 05:04 AM
LINESUPER's Avatar
Default Head bolts?
Ok, NooB question. I just dropped my "S" at the shop to have an SOS supercharger installed. Prior to the installation, I am having the valve retainers replaced (from AP1 to AP2 version) . The shop foreman ask me a question that I really should have considered, didn't, but with the stock boost on the supercharger, I didn't think it was really necessary. Now I am having second thoughts. Should I have the stock head bolts replace with arp studs? My plans may include going to 9psi in the future, but for now the stock 6 psi is where I will be. Any opinions and suggestions are welcome. Thanks
Old Mar 23, 2011 | 05:30 AM
Sideways's Avatar
Factory head bolts are fine for most superchargers. I ran 17 psi on mine with no problems.
Old Mar 23, 2011 | 05:42 AM
passmans2kny's Avatar
if your only going 9 psi I wouldn't touch the motor
hondaguys2k's Avatar
from what i hear the OEM bolts seal just fine running low-moderate boost on turbo/supercharged setups. i was considering going to ARP bolts myself but was told they are a waste of money and can safely run 14psi on my turbo setup without them.
Old Mar 23, 2011 | 06:22 AM
siadam's Avatar
People making 700whp on stock blocks, so the headstuds are fine, BUT if you pull the head completely, I'd suggest replacing them w/ARP's @ that point.
Old Mar 23, 2011 | 07:44 AM
LINESUPER's Avatar
I agree - I am having the head pulled to install the valve retainers. which is why the shop foreman ask about the studs, since the head is being pulled. I likely will not have them install arp studs though. I all ready have way too much invested to blow cash on studs I don't need. I guess if I had really thought about the process for replacing the valve retainers, I would have looked at 3 mm head gasket, arp bolts and all. The things you can spend cash on this car are many, but not necessarily money well spent.
Old Mar 23, 2011 | 08:59 AM
D1sclaimer's Avatar
The shop is pulling the head to install valve retainers?
You need to find a new shop to go to. You can do that without removing the head.
Old Mar 23, 2011 | 11:29 AM
siadam's Avatar
So you agree with what I said, but aren't doing what I suggested, lol?
OEM head bolts are typically not re-useable. They can be re-used, just like wearing day old underwear, but not recommended.
Again, if you pull the head, spend the $100 bucks on studs, or re-buy oem bolts if you like.
Old Mar 23, 2011 | 12:11 PM
redboost10's Avatar
Are ARP's the only option for head/main studs?
Old Mar 23, 2011 | 12:25 PM
LINESUPER's Avatar
I know, but its a Honda shop doing the work, with a factory tech - Honda reccomends head removal, rather than the work around with holding the valves up with airpressure. Plus, you do it their way, they stand behind their work. bottom line, I'm a Noob, and I trust these guys - in 8 years of ownership on the S and 20 + years of Honda shop work they have never burned me. As a testomony of their dedication, I know people who will drive 3 hours to this shop, just to have them do their work.. but you are right, you can replace them without removing the head.
Originally Posted by LINESUPER' timestamp='1300895068' post='20389549
[quote name='siadam' timestamp='1300890168' post='20389335']
[/quote]
They are replacing the bolts with OEM. They will put in the ARP studs if I want them. Thats why they ask. i am taking away from this conversation that there is a significant advantage to the ARP studs over the OEM, but I would not realize the advantage in my application. Is that correct? My question goes to if their is any real advantage of ARP over OEM. Anyway, as I stated, Noob question.
Just dropped the supercharger off at the shop, and they will likely begin work this week. I appreciate the input.
